Guide: How to Replace Fuel Injectors on 3.5L/3.7L I5
Old Jul 19, 2021 | 10:36 PM
Dylan Rogers's Avatar
Default Guide: How to Replace Fuel Injectors on 3.5L/3.7L I5
Hey everyone,
I made a quick guide on how to replace the fuel injectors on the 3.5L and 3.7L I5's. I figure this might help some people out. I was certainly intimidated by the project (mainly removing the intake manifold) but it was actually pretty straight forward. I have also included factory torque specs and other important information from the factory service manual. Enjoy!
Old Jul 21, 2021 | 01:05 PM
H3Luxembourg's Avatar
Thanks for that. Any issues , bad codes or reprogram BCM / PCM needed ?
Old Jul 21, 2021 | 05:57 PM
You're welcome! No issues or codes result and no re-programming is required if using the same model injectors.
I "tuned" the PCM in my scenario due to different flow rates in the injectors I chose. I ended up switching from 2006 3.5L to 2008 3.7L injectors (different connectors and flow rate but fit the fuel rail interchangeably), so I "tuned" my PCM for the higher flow rate. It still ran normally prior to tuning but I imagine the setup is more efficient with a tune to adjust for flow rate.
Old Jul 23, 2021 | 11:07 AM
GrampaEJ
Feb 15, 2019 11:43 PM
Billarmao
Dec 21, 2015 02:18 PM
yardcrew
Aug 12, 2014 08:06 PM
palmxjjsi
Jul 26, 2011 01:12 PM
NIK1
Feb 2, 2009 07:44 PM
