Exhaust Manifold / Heat Shield
Old Feb 13, 2021 | 04:59 PM
rconkin's Avatar
Default Exhaust Manifold / Heat Shield
I bought my H3 back in the summer and knew it had an exhaust leak at the time. I finally got some time to check it out. I had seen a video where someone had used a shop vac to blow in the exhaust to find leaks so I did that. I was hoping it was just the Oxygen sensor. I started spraying soapy water and it did leak around the sensor. Unfortunately, I found 2 more leaks. Exhaust gasket at #2 cylinder and the manifold is also cracked at end of section coming from #2 cylinder. I'm going to put it back together as I have to use it to drive to work. I was just wondering if it would hurt anything to leave the heat shield off until I replace the manifold. Also, what brand manifold would you recommend I replace it with?
Old Feb 13, 2021 | 06:26 PM
I wouldn't drive without heat shield.
Get your pen and paper ready for a grocery list:
  • Magnaflow manifold (if you have extra money to throw away) or
  • Walker Ultra manifold (1/2 the price). Note: Either have 2 options, make sure to verify 1 or 2, 02 ports on current manifold.
  • Exhaust manifold to head gasket (Mahle or Victor Reinz)
  • Exhaust pipe to manifold gasket (Mahle or Victor Reinz)
  • Exhaust manifold studs & nuts (8.8-10.9ss)
  • Exhaust pipe to manifold studs & nuts (8.8-10.9ss)
  • Beer
Curious to see a picture of your "crack"? Many years ago, I had to replace the gaskets and upgraded to ss studs, no leaks since.
Old Feb 13, 2021 | 06:44 PM
rconkin's Avatar
I’m just n phone and trying to attach video. If this doesn’t work, I’ll do a screenshot.
Old Feb 13, 2021 | 06:47 PM
rconkin's Avatar
Old Feb 13, 2021 | 07:29 PM
I only see bubbles? Hole or crack? Regardless easy repair with a cheap arc(aka:stick) welder.
Old Feb 13, 2021 | 07:32 PM
rconkin's Avatar
It's a crack about 1-1/2" long. Really not visible until I sprayed the soapy water on. I could pull it then and have one of the mechanics weld it at work then. Thanks.
Old Feb 15, 2021 | 04:58 PM
Justinh's Avatar
If you got the $$ for a new one, would it be better just to get a new one if you are going to pull off the old one? If that crack is near the mounting surface, what is the risk of warping?
Old Feb 15, 2021 | 06:02 PM
wpage's Avatar
Weld it then check the torks on the studs that hold the manifold. Should be good to go...
Old Feb 15, 2021 | 07:29 PM
Why waste money? OP also has a leak at the o2 sensor (G18MM gasket), a leak at the manifold to head gasket, (MAHLE MS19755 gasket) which requires manifold removal for gasket replacement. Check & deck while removed & weld if needed. Replace the manifold bolts, with studs @ 12.9 or 10.9 & nuts, then forget about it, and keep that extra money banked. I could spend $800+ on a new exhaust manifold, however my oe manifold still performs as intended! BTW, I'm down to $185 month out-of-pocket, since purchase, for PURCHASE, MAINTENANCE, & REPAIRS.
Old Feb 16, 2021 | 03:35 PM
H3Luxembourg's Avatar
Amen bro
ben1272
Sep 3, 2020 07:22 PM
Gdraft
May 6, 2020 08:24 AM
Davidf226
Nov 15, 2016 04:34 PM
pepper1
Jun 1, 2012 11:53 PM
2luke2
Mar 30, 2007 12:11 PM
