engine misfire
Old Aug 29, 2015 | 08:53 AM
swampdawg's Avatar
Default engine misfire
I changed sparkplugs in my 07; H3 yesterday. When completed, I cranked engine and it was missing badly at first and after it ran a few minutes it cleared up a little. As a precaution I removed all 5 coils and made sure all plugs were properly tightened. Replaced coils and cranked with same results.I slowly increased rpms and miss cleared up around 1500 rpm. I reved engine several times and check engine light came on. Code shows random misfire on #2 cylinder. Any suggestions to correct this problem?
Old Aug 29, 2015 | 09:03 AM
You have to make sure that the coil pack is correctly and completely on the plug before you tighten the coil pack retaining bolt. Check the wiring to coil pack #2 for, make sure it is properly connected and shows no signs of cracks or missing insulation.
If it still persists, swap coil pack #2 with #1, see if the miss follows the coil pack. If it does, get a new coil pack.
What spark plugs did you put in? Stick with the OEM AC Delcos, aftermarket plugs are never a good idea for the I5s.
Old Aug 29, 2015 | 09:21 AM
swampdawg's Avatar
thanks, I will give this a try
Old Aug 31, 2015 | 02:56 PM
swampdawg's Avatar
Default still missing
I replaced all 5 coil packs and engine is still missing. new codes: 300 random misfire. 302, # 2 cylinder misfire. 102 MAF circuit low output. 352, coil b primary/secondary. I had no problems what so ever until I changed plugs. Any other suggestions??
Old Sep 2, 2015 | 01:00 PM
Bunger's Avatar
What plugs did you put in?
Old Sep 2, 2015 | 01:15 PM
And.... did you gap them???
Clean the connector to the MAF with CRC electrical contact cleaner, that has to be snapped on fully and have a good constant contact.
Old Sep 3, 2015 | 08:30 AM
swampdawg's Avatar
AC Delco 41-103. Gap .43
Old Sep 3, 2015 | 08:33 AM
swampdawg's Avatar
AC Delco 41-103. Gap .43 the only issue remaining is code 352. I will get contact cleaner and do as suggested. All help greatly appreciated.
Old Sep 3, 2015 | 08:46 AM
OK on the plugs.
Your P0352 and P0302 are telling us that you have an intermittent fault in the wiring to your coil #2. There is a primary circuit (battery) and secondary circuit (PCM coil fire control and monitor) which is grounded by the PCM every time the coil needs to fire.
Most likely caused by, like I said before, a wiring problem to the coil. This could be a harness short, an incomplete connection (the connector is not fully snapped in or its connector/lock is broke), dirty connectior to the coil, or a PCM fault. The PCM fault is least likely, and something you did not disturb when changing plugs.
Old Sep 7, 2015 | 09:43 PM
happythree's Avatar
thats .043 huh?!
eainsurance
19
Dec 12, 2018 09:46 AM
ryan
Aug 22, 2011 08:51 PM
06H34ME
Feb 15, 2010 08:57 AM
azz7772
Jan 10, 2008 10:03 AM
HummerGuy
Feb 20, 2007 12:43 AM
