Driver side window issues ?
Old May 5, 2023 | 07:26 PM
Millertime045's Avatar
Default Driver side window issues ?
Ok so I got my hummer back from shop, all windows roll up fine all of sudden my drivers side will not, so I ordered new switch it works for like 2 mins then stops ??? Any clue what’s goin on
Old May 6, 2023 | 09:11 AM
Golden Hurricane's Avatar
I would bet that the wiring to the switch is loose. That's what I would check first. Reminds me of Jaguar's problem with Lucas...Lucas earned the nickname...Prince of Darkness! Seems like a lot of Jaguar owners would be driving along at night with lights ON...and then...Complete DARKNESS! The Lucas bullet connectors would come loose!
Old May 6, 2023 | 09:18 AM
You might try Tainter's suggestion for a RESET of the BCM. Simply disconnect the Positive battery terminal and wait five minutes. Then reconnect.
If that doesn't work, it might be a ground wire.
BTW, do you have a sunroof and have you had any wet spots on the passenger floorboard...which would indicate a BCM problem!
Enjoy your day! Happy Trails!
Old May 6, 2023 | 09:44 AM
no sunroof literally came back from shop all 3 worked but it I replaced switch works then soon I push button car dings snd it dies
Old May 6, 2023 | 09:46 AM
just strange it be a wire is it blue one or white one ? I put new switch if it will work for like 30 seconds cars makes dinging sound snd it died again
Old May 6, 2023 | 10:22 AM
Sounds like a ground wire to me.
Check (verify)...be extremely thorough when checking ground wire issues!
Second place would be the ACC contact on the ignition switch...check Schwartzzy... spelling? I think he may have posted a .PDF of the wiring schematic. If not, Hummerz, Doc Olds and Tainter may have that wiring schematic!
BCM issues would be a distant third place, especially if you have NOT had any water leaks.
Hope these thoughts help you!
Happy Trails!
Old May 13, 2023 | 12:11 AM
Any other ideas works fine when I unplugged it plugged back up soon a roll up inside dings and stops working idk went to shop came back k like this all 3 other windows work fine
Old May 13, 2023 | 12:40 PM
are you able to hold the down position from 10 seconds then raise the window all the way and hold for 10 seconds or does it crap out before that?
Old May 13, 2023 | 04:56 PM
i can try it out but I unplug it works fine then car dings and it’s dead again but if I unplug and repeat goes up and down
Old May 13, 2023 | 05:02 PM
Fast video
