Driver seat stuck forward
Moved my driver seat all the way forward and it won't move back?
Electric seat or manual???
Electric
We moved it all the way forward and now it won't move back. |
Sorry for the repeated info...
We checked the tracks and no obstructions either. |
Could be the screw has run out the end of the adjuster. I've seen, and had to repair this on other GM cars.
Try looking underneath, for the long threaded rod, and where it engages with a threaded plastic piece. Also, you might watch for the rod spinning, while you push the button. Could be a fuse thing? Good Luck. EJ |
Will check that. Took the seat out and the fuse was out but not sure if trying to keep pushing the back button created that issue, we did notice when we kept pushing the button the lights slightly flickered?
