cv joint noise?
Old Oct 24, 2019 | 09:07 PM
tuesdaytuesday's Avatar
Default cv joint noise?
Hi all, Im having this noise coming from driver side front wheel, when steering all the way(70%+) to the right, there's this big clicking/banging noise.
I did a bit of research, seems like it's the cv joint has gone bad. Here's my video when pulling off my driveway. Can anyone help me verify this is cv joint noise? And is this something DIY fixable?
Old Oct 24, 2019 | 09:59 PM
Sound pitch to high for drive axle. Sounds more like steering/suspension noise. Does it make a noise driving down the road?
Old Oct 24, 2019 | 10:14 PM
It only happens when steering 70%+ right, forward or backward. If I drive straight, it doesn't make the noise.
Old Oct 24, 2019 | 10:43 PM
It only makes the noise when moving?
Old Oct 24, 2019 | 11:05 PM
Thats correct. If I park it on the driveway, and turn the steering wheel all the way to the left or right, no noise at all.
Noise only comes up when wheels are rolling and the steering wheel is turned right 70% all the way.
Old Oct 24, 2019 | 11:08 PM
Old Oct 25, 2019 | 07:07 AM
Definitely sounds like the CV is binding.
Old Oct 25, 2019 | 01:07 PM
Amazes me. People ask a question about their vehicle and never indicate YEAR and MILES!
Looks like you are turning a bunch more than 70%. Did you do a careful visual inspection of the CV Joints under bright light?
Old Oct 25, 2019 | 01:11 PM
Ejwins's Avatar
Haha I love doc olds responses. I want to make a collection if these and just read them when I'm in a bad mood. First you get slammed, and then you immediately get helped.
Old Oct 25, 2019 | 01:14 PM
Ejwins's Avatar
I had clanking noises twice from the wheels, once it was the upper control arm which I replaced with a moog. You can test that by raising the h3 and pushing on the top of the tire, if it moves, then bingo.
The other time it was cv joint, and you obviously already know all about that.
Tie rod ends might be worth looking at as well.
