CSF radiator replacement for H3/H3T
Wondering what type of warranty their offering with this radiator sounds like their saying a lifetime... are they gonna really back that up with a warranty ?
Warranty Information
CSF takes pride in the quality of its products and offers one of the best warranty's in the industry. Please refer to the warranty card in the shipping carton for details.
CSF's warranty is applicable only to the original owner of the vehicle. Original paper work verifying the proof of purchase and pre-installation cooling system checklist signed by the professional installer is required to process warranty claims.
All warranty claims should be directed to the point of purchase. Take care of your radiator, as under the circumstances listed below the warranty is void:
Warranty Busters
If the radiator is installed and returns deformed (bulging tanks, warped core etc) it is an indication that the radiator is the victim of some other problem not the cause. The deformation is a result of the radiator being subjected to extremely high pressure and or temperature caused by any of the following reasons: Defective Pressure Cap, Defective Head Gasket, Defective Temperature gauge (incorrect readings), Defective Water Pump etc. Such units are not covered under the warranty.
If a radiator seems to have a "fit problem" there is the possibility that there is some confusion about a multi-fit radiator that might look different. Your nearest CSF WD can clarify the application, just give them a call. A perceived fit problem is not covered under warranty.
If a unit is damaged in shipping, please file a claim with the carrier. Damages caused during shipping, installation or handling are not covered under warranty.
Any repairs or alterations to the unit will automatically void the warranty.
Any form of abuse, including the use of improper coolant mixtures, damage caused by steam, corrosion etc and use on commercial vehicles voids the warranty. It is the vehicle owners’ responsibility to maintain the cooling system as specified in the owners manual.
Correct Antifreeze Coolant
It is very important that you use the correct antifreeze coolant (A/FC) for your radiator. All quality A/FC ‘s will provide both freeze-up and boil-over protection (see A/FC bottle for details). A/FC’s must also provide anti-corrosion protection for the metals of your radiator and cooling passages within your vehicles engine. The type of metal core on the radiator determines the type of coolant that should be used.
Core Type Coolant Type
Copper-Brass core GM 6038 or equivalent or Hybrid Anti Freeze. Coolant like Valvoline G05.
Aluminum Core GM 6043 or equivalent or Extended Life. Anti Freeze Coolants like Dexcool or other Organic coolants or Hybrid Anti Freezes like Valvoline G05.
When a new radiator is installed, CSF requires a complete flush and fill utilizing new coolant mixed 50/50 with distilled, deionized or demineralized water. Using the wrong coolant may result in corrosion, which can cause core leaks or other cooling system damage and will void the warranty.
Lots of rules, I know.....but still a great product. I've been watching the temp gauge carefully when I drive that H3, it runs at about 1/4 temp most of the time, until you stop. Then it sits at the normal 1/2 mark. Usually I see them running at 1/2 temp even on the highway, so this one seems to run a lot cooler!
