Code p0420
I have a 2008 H3 Alpha with 122,000 miles on it. I get a code P0420 about every 100 miles or so. Catalytic converter inefficient bank 1. Started getting this after I changed out the bank one O2 sensor 1. I moved all the sensors from bank 1 to bank two and visa versa. Figured if issue moved it would point to a bad sensor. Issued stayed on bank 1. Guess I have a weak catalytic converter. Always used tier 1 fuel. Can anybody recommend a good catalytic converter that wont break the bank and do I have to replace both sides? If somebody has a trick to clean the catalytic converter I would be willing to try that or if you think I am stuck changing the converter out that is what I will do. Thank you
I just find it odd that I can clear the code and it doesn't come back for maybe a couple hundred miles. I would think if the cat was inefficient the code would come back fairly shortly after driving again.
That's how mine is; sometimes I can go several weeks, other times it will trip the code every other day. Seems to be getting worse lately. Drives me nuts, and I'm getting ready to smog it, so I need to time it just right!!!
Extend the cat monitor 02 sensor (down stream sensor, behind the cat)
Many how to videos on YT.
https://www.youtube.com/watch?v=TxUya70kkQk
Actually you should be careful with the "Used Car Salesman" repairs. You can do damage to an otherwise fine motor when faking the PCM to not monitor CAT efficiency so that you will not know how bad it gets. Ever see people driving with their exhaust glowing red, car smoking, clueless to their problem?
