Code B2725
Old Oct 10, 2020 | 04:19 AM
Alex DjFlaco's Avatar
Default Code B2725
I'm a bit confuse with this code. I know what its saying but there so many different things people search and find. Im not sure weather i need like a sensor or just the whole 4x4 panel.
Old Oct 10, 2020 | 01:22 PM
Service 4 Wheel drive error
HUMMER DTC B2725
Make:HUMMER
Code:B2725
Definition:ATC Mode Switch Circuit Malfunction
Description:Ignition ON. System voltage 9-18 V.
Cause:
  • The TCCM constantly monitors the voltage on the switch signal circuit.
  • If the system detects a voltage level under 0.3 volt or greater than 0.5 volts for 600 seconds, the DTC is logged.
hummer_on_fumes
Jun 21, 2018 01:10 PM
hummermongolia
Oct 4, 2015 07:55 PM
mephis2012
May 4, 2015 10:21 PM
gotafish
Apr 21, 2012 03:54 PM
agnt549
Mar 4, 2011 07:55 AM
