blinking rear tail light issue
Old Nov 14, 2008 | 11:57 PM
mrmseto's Avatar
Default blinking rear tail light issue
Hi ya all.
So heres my problem. A few weeks ago i noticed that my right turn signal indicator "ticks" or signals alot faster then the left turn signal. About 2 x faster. A friend pointed out that the right rear brake light and turn indicator does not work either. Day time running lights that are red works fine. Am i wasting time by replacing the bulb or is there some electrical problem issue going on here. These 2 issues must be related I think. any ideas. thanks
I' m driving a 2007 H3Hummer
Old Nov 15, 2008 | 09:26 AM
H3Lee's Avatar
Default RE: blinking rear tail light issue
I think the filament in the bulb for DRL is different for turn signal. So, if that filament is burned out, it will cause an indicator to blink faster than normal. Someone correct me if I'm wrong here.
Old Nov 15, 2008 | 10:51 AM
lucky19942001's Avatar
replace the bulb,it always blinks faster,thats how u no u need a new one.
[IMG]local://upfiles/4035/961DFC679105461D9113AFFCC19F6692.jpg[/IMG]
Old Nov 19, 2008 | 06:31 PM
croatone's Avatar
Make sure to replace the bulbs and replace them with the correct ones. I believe hummer 4 life to be correct about the speed of them. Blinker speed is load dependant. less draw will blink faster.
Old Oct 1, 2009 | 04:34 PM
temka892004's Avatar
i have the same problem, i have changed the light bulbs but nothing changes. It blinks faster than the other side and the bad side bulb isn't bright enough also (can barely see it blinking)? any other information on this subject would be great. thanx
Old Mar 19, 2010 | 09:38 PM
djezrock's Avatar
What, nothing, no more replies?
I have the same problem. Going to change buld and see if it fixed the problem
dj
Old Mar 20, 2010 | 10:02 AM
OUTLAW's Avatar
You have a bulb problem check all your bulbs and replace any that don't work right with the correct bulb. Look in your H3 book for correct bulb.
Old Dec 14, 2024 | 07:24 PM
Taneo22's Avatar
yeah I have a 2008 alpha with the same issue, no right turn or brake light. (most of the time)
I noticed in addition to that issue, the right 12v outlet also gos out. I'm sure at this point it's the BCM that GM was so thoughtful to discontinue.
I've taken it to every electrical specialist in Birmingham and no one has a solution. sometimes everything works great, most times it doesn't.
Can't find a new BCM anywhere, only junkyard options so far. I am waiting to hear from a guy about possibly rebuilding a old BCM but we shall see how that progresses.
Please post if any of you ever find a viable solution. I will also follow up with any developments.
cheers,
Rick
Old Dec 14, 2024 | 07:59 PM
BLK WLF's Avatar
cheers,
Rick
I really think you should start your own thread as the last comment was done 14 years ago.
Welcome and good luck.
Many good mechanics on here that will help you further in the future.
Old Dec 16, 2024 | 02:31 PM
cheers,
Rick
LOOK before you POST anything. Please avoid digging up Old Azzed Threads. READ: Old Threads/'Necro-Bumping'
7ducati
Sep 13, 2021 09:06 AM
VIPNiSS
Dec 13, 2016 03:15 PM
register1987
Jul 20, 2015 03:01 AM
markushp
Jul 17, 2009 02:22 PM
Antonio Dom.Rep.
Jun 24, 2008 11:23 AM
