Anyone tried LED headlight bulbs?
Old Jan 22, 2014 | 06:58 AM
  #31
LoJac963's Avatar
Originally Posted by Robgims
Well, im still doing research and came across the Morimoto brand of HID's. They are highly regarded as the best you can buy. Let's see.................
9006: Morimoto Elite HID System - HID Systems from The Retrofit Source Inc
Honestly it all comes from China. You'd be wasting your money buying into their hype. Just my opinion.
Old Jan 22, 2014 | 08:12 AM
  #32
wfturner's Avatar
No they are not.
Old Jan 22, 2014 | 09:44 PM
  #33
purplelife's Avatar
I retro-ed my 2007 yukon denali headlights before buying my H2. I can tell you Hid's are well worth it IF done correctly. First of all, those Starr lights does not come with output pics (sketchy). You may want to look at the Retrofit Hid site and check out their options. You should not place hid bulbs in halogen housings. The light cannot be focused, therefore blinding oncoming drivers. Projectors are what hid's require (focusing light downwards towards the road). Those ebay kits do not last and their output is mediocre! Retrofit sites take proven oem projectors (bmw, lexus, acura, infinity, mercedes) and supply you with all the equipment you need to install them properly on your vehicle (plus they are badass)!!
Old Feb 11, 2014 | 01:01 PM
  #34
Robgims's Avatar
Well, i got my HIDs today but before i install them i wanted to find out if it was possible to switch and make the fog lights the DRLs instead of the headlights. The reason i want to do this is so that i can maintain the auto feature. I also know that the HIDs wont work as the DRLs. I did a few searches but could not find an answer. Tnks.
Old Feb 11, 2014 | 03:11 PM
  #35
staggs's Avatar
my hid's work fine as daytime running lamps, never had a problem.
Old Feb 11, 2014 | 03:47 PM
  #36
Robgims's Avatar
Wow, i read that the current was at a low level for the DRLs and the power would not be sufficient to fully power the HIDs.
Old Feb 24, 2014 | 06:15 PM
  #37
Robgims's Avatar
Wink Got the Morimoto 3five kit
Installed my HID kit and im super pleased! Should have done this long ago, I would have saved myself allot of headaches. The kit is super beefy and looks heavy duty! I finally got what I was looking for, matching the LED fogs and improving my headlights. The dudes over at Morimoto said that they don't recommend running the HIDs as running lights (since it is not a consistant power supply it will cut down on the life of the bulbs) so im turning them on manually. Here are some pics.
Attached Thumbnails Anyone tried LED headlight bulbs?-cam00748.jpg   Anyone tried LED headlight bulbs?-cam00749.jpg
Old Feb 24, 2014 | 08:59 PM
  #38
H3Ray's Avatar
Looks Good ....
Old Jul 8, 2014 | 08:09 AM
  #39
Threedog's Avatar
Am about to replace the HID lights on my 05 H2. There is one option I don't know whether to get... the "warning canceler". I installed it on my BMW motorcycle and basically, it tricks the computer to thinking that everything is normal on your lights and doesn't give error messages. Question is, does anyone know if the Hummer line gives error messages on faulty headlights? If so, I'll buy the cancelers. If not, I'd rather not pay $10 for them.
Old Jul 8, 2014 | 11:09 AM
  #40
badss98's Avatar
No warning canceler is needed on the h2 just make sure you get the relay harness as these are not plug and play as standard bulbs
