Advice on BCM
Hey Guys
The 06 truck came to me with a dead battery and after sitting for a year so i have no background on it She is up and running now but the keyless remotes wont unlock the doors. My buddy has a key shop he tested the remotes for signal and battery both are good. I fell strongly that the receiver no good. I have 3 questions Looking to confirm that the BCM is the brain for the keyless remote . I cannot reset the TPM im not sure if those signals go to the BCM ? How can i trouble shoot the BCM if that is the thing to be looking at. Thank you Steve |
If you cannot reset the TPMS on a 2006, it is because you need new sensors they have a life expectancy of 10 years. Unless you know the prior owner recently replaced them, don't bother until you install new ones. I would recommend ACDelco, not el cheapos.
With a 2006 that has been sitting a long time, you lost the fob connections. Happens to a lot of 06/07s. You can play with those until blue in the face, but it would be cheaper and you get better range with aftermarket keyless entry and remote start. Yes, the OEM keyless entry functions through the BCM. They can have issues if they sit too long, but not always. Balance price for a new BCM and programming vs new aftermarket fobs if everything else functions as it should. You can scan the BCM with a full scanner (not an engine code reader) to check functions. Another thing you need to do if not done already is to hack off the crappy azzed battery terminal connectors and replace them with a quality aftermarket set like Stingers or your favorite brand. |
HI Doc Olds
thank you for you comments, i will order some new battery clamps ASAP! The H3 is a manual so i probably wont be installing the aftermarket remote start, the OEM keyless is good for me. Can you inform me on what programing is involved with replacing the BCM? I dont know what happens if i buy a replacement BCM and plug it in. Thank you very much Steve |
Say hello to the dealership lol. I went there last summer to get a new fob programmed. It is the same for BCM. Dealer programmed.
(Post 364926)
thank you Steve |
(Post 364899)
https://cimg9.ibsrv.net/gimg/www.hum...56bb291702.jpg |
