2007 H3 issue
Old Oct 28, 2019 | 07:22 AM
Rhonda Aleman Conway's Avatar
Default 2007 H3 issue
My H3 shuts off when I try to put it in gear. The wipers start going and won't stop. It starts and again when I put it in gear, it cuts off. What would be causing this?
Old Oct 28, 2019 | 09:17 AM
MOVED to the H3 section, where all H3 questions belong.
MILES? Recent work?
Do you have a sunroof? If so, has the passenger side floor ever been wet?
Old Oct 31, 2019 | 07:35 PM
UcraDen's Avatar
dude!!!!!! )))))))
its just happened to me )))))))))
****ing fuse box bull****.. ok..
basically i just change the alternator, and to do such, some people would suggest to remove completely the battery, the fuse box with its cradle and disconnect the fuel line. i did it all except the fuel line- **** it! i just move aside a bit the AC line.
anyways- long story short, my fuse box fuses was all oxydided so i pull it off again, clean ALL the contacts, inside, i pass some sand paper the contacts of the relays and fuses, put some dielectric grease and put it back...
so everything lit up like a cristmass tree, except when i start the car and put it into the gear, the vehicle shuts down, and wipers start to work.
i fix it just tapping the fuse box where it got connected with those 2 big connectors underneath.. i just assume that it has faulty contacts that trigger that whole bull****.
i you didn't fix it yet, just turn on the car, and start to **** around with fuse box bu tapping it, playing with connectors if it will make any changes. that my fix so far.
but if someone had the same trouble, i really like to hear what exactly is...
Old Nov 1, 2019 | 10:32 AM
So you advise to the world to fix this problem is tap on the fuse box?
When someone posts a question about an issue leaving out important information to incorporate in a possible solution, I ask them for that information in response. If they are not going to bother providing it, I am not gonna bother guessing.
Also, I am pretty certain Rhonda is not a dude. Wacky wipers is a symptom of a known problem, but since the OP doesn't have time to answer my questions, I got better stuff to do.
Old Nov 1, 2019 | 01:20 PM
lol.. If a doubt, check fb out.
Old Nov 1, 2019 | 06:09 PM
UcraDen's Avatar
well, so far that what i did... i know its stupid, but its indicate that problem might be in the fuse box. im actually thinking to ask GM how much they want for brand new box.if it will be sky high, i might consider to desasemble it fully to play around with it..
Old Nov 1, 2019 | 08:53 PM
You are not helping ne1 with your gibberish! Live and Learn!
Btw, Rhonda we are here to help, just ignore:
Old Nov 2, 2019 | 10:07 AM
Mark Steadman's Avatar
Cool
You can get brand new fuse boxes on eBay for about $200. My guess is it’s not the fuse box, it’s one of the wires feeding the fuse box or a bad connector.
kevino
Jan 28, 2019 07:55 AM
chevin
Sep 6, 2018 01:56 AM
ImNoSaint
Feb 5, 2014 10:16 PM
neverendingproject
Jul 8, 2009 10:37 PM
rromas00
18
Jun 23, 2008 05:24 PM
