2007 H3 I have a clicking noise periodically while under acceleration
Old Aug 9, 2018 | 02:23 PM
Bobber_88's Avatar
Default 2007 H3 I have a clicking noise periodically while under acceleration
any advice? Sounds like could be drive shaft or u joint
Old Aug 10, 2018 | 07:19 AM
choochmalooch's Avatar
Cool
I had a similar issue and it took me awhile to diagnose. When I rotated my tires I found the problem. It wound up being the chrome peeling form the inside of my rims and coming into contact with my brake calipers as my tires rotated. If your H3 is an X and has chrome rims look at the inside surface.
Old Aug 10, 2018 | 07:43 AM
RKSmith163's Avatar
I had the same issue.
Old Aug 10, 2018 | 10:52 AM
Bobber_88's Avatar
I have aftermarket rims on mine- Ultra Type 50- I believe are aluminum alloy rims. I checked for any debris but see nothing. Noise only happens when under acceleration, if I let off the gas the noise quits. Thinking it has to be when the drive shaft is under a load. I snapped a couple pics of front end. Looks like passenger side may have a leak.
Old Aug 10, 2018 | 11:51 AM
What you have in the pics are the Half Shafts (between the front Diff and Wheel Hubs), the drive (propeller) shafts come out of the T Case into the front and rear Differentials.
Grab hold of the front drive shaft and see if it has any play, there should be none. U Joints start soft and get noisier as they go, usually some clunks and squeeks, not hard to tell when they go. The CV joint will make a racket and cause vibration when it gets tired. Clicking is not the way I would describe the symptom of failure.
The CV joint at the rear is can be rebuilt with a kit, the front U Joint can be replaced.
If your Half Shaft boots are not torn or cracked, they should be good. If they are wearing out they will start making noise and even feel choppy in tight very low speed turns, like into a tight parking space tight turn.
Old Aug 10, 2018 | 12:10 PM
Bobber_88's Avatar
I will look into the front driveshaft for play. Definitely a clicking sound almost like a card in the spokes of a bicycle. Sometimes loud sometimes quiet, sometimes no sound at all. When it is noisy it will quit if I am not on the gas petal. As far as the half shafts- is it normal to have a gap on the passenger side near the diff? I got stuck in a deep rut while fixing some pasture fence recently and just want to make sure I didn’t tear something up.
Old Aug 10, 2018 | 12:12 PM
Bobber_88's Avatar
I do not have any shaking in the wheel or anything, drives normal just makes the clicking sound
Old Aug 10, 2018 | 12:54 PM
When the Half Shaft is installed into the Diff or the Driver side axle tube, it is held into position by a detent in the shaft. When you push the Half Shaft end into the carrier, it "clicks" into position. H3 Half Shaft inner CV joint can move liner, so you could get under there and see if it moves in or out of the Diff, there should be no play. If there is any play, try to push it into the diff until you feel the click into its spot.
I have heard of aftermarket Half Shafts being too short and popping out of the diff stripping the shaft's splines. That would make a racket for sure.
Old Aug 18, 2018 | 01:17 PM
Bobber_88's Avatar
Pics of the front U joint. The shackle looks bad. Could this be the issue?
This is the shackle forward of the front U joint. Cracked
Could this be my issue
Old Sep 5, 2018 | 09:15 AM
heyttsguy's Avatar
Sheared off manifold bolt
Don't rule out a leaking exhaust manifold as well. I just discovered a missing bolt (broken off) on my driver's side manifold on the 5.3L. It ticks under acceleration until the manifold warms up and expands. Apparently it's a common problem.
