2006 Hummer H3 Question
Just bought it about 2 weeks ago. I noticed this morning I had water in my floor board on passenger side. It does not have a sunroof. I climbed up and looked and I have 6 holes that are threaded up toward the windshield. My outer trim panel on right side is real loose on top. Any idea what those holes are for. I thought it was for roof lights but not sure.
Welcome to HF. I MOVED this for you as the New Member section is strictly for introductions and NOT for Tech Questions, just like it says in the sticky thread at the top.
The holes were for the over the cab roof lights, the orange ones. They, and the roof top Off Road lights. are no longer available so you might as well figure out a way to seal them with silicone or the like.
Thee "outer trim panel" you refer to is the front of the roof rail trim which is held in place by rivnuts, which can break when abused and then leak. Same deal, pull the molding, inspect and repair.
Good luck.
Good luck.
StevieDay
Apr 29, 2016 02:42 AM
ZR-1 Mark
Sep 17, 2009 12:53 PM
