2006 H3: Service Stab Sys, Traction Failed, Reduced Power II.
Just got the same with my 2008 Alpha: Running offroad (nothing too major, mostly fire roads with some decent ruts and ledges) in 4HI LOCK for about 2 hours. Suddenly got the SERVICE STAB SYS -- TRACTION FAILED -- REDUCED POWER message on the dash, along with the CEL and Stabilitrac light. Luckily, was already past the tougher sections and had only smooth dirt roads left; nursed it home, checked the codes; P0452 Evap Pressure Sensor, P0641 Sensor Reference Voltage A Open, P0106 Manifold Absolute Pressure. Clearing the codes doesn't change anything, it immediately throws them again when you start it up.
BTW, I know this was a thread from January, but I wasn't sure whether to bump or start my own. Seems if someone starts a new thread here, shouts of "use the search feature" come up, but if they bump an older thread, shouts of "this is an old thread, start your own" come up. If I'm wrong here, just let me know and I'll delete this and start a new one instead. Thanks.
Glad you got your issues under control. Carry on.
I've posted this in another thread but I thought I should post it here as well. I've just cleaned up the spark plugs with petrol and now she runs fine. Mine's a h3 3.7 litre 5 cyl 2007 model. Hope this helps. Good luck.
No need to pull the plugs unless they are worn. Just use a better "petrol"
https://www.sunoco.com/quality-fuels/our-fuels/
Belated response
My problem is in the morning when starting the engine. I am pressing the race to the max then in a few seconds it is off. I repeated it for 15-20 minutes !! Until engine is running. Then I move. But never off while driving.
The same msg. Stab system, traction failed, reduced power
So what z ur advice pls ?
Hello everyone!
I have my favorite car H3 model 2007. But, 5 to 6 months ago, I have the problem 5 months ago: in morning and after a long stop (7 to 8 hours), when I start the engine, it is stopped with the message on dash: service stab system, traction failed, reduced power.
if I instantly start the engine again, it did not start although all lights are on.
I wait for 20 to 30 seconds then I try starting engine. it works then stopped.
again after 20 second I start it again with pressing on the race roughly. and stopping again.
so, after 10 to fifteen minutes doing the same, it finally works.
this happens especially during the cold time with a long stop here in gulf.
any advice pls.
any advice pls.
Belated response
Please use the SEARCH function.
Olds & Hummerz,
Here is what I've done,
Replaced:
Throttle body (gone thru 3, in passed 6 years),
replaced pedal assembly,
speed sensor,
crank sensor,
replaced transmission,
encoder motor (3 again),
PCM (once already),
camshaft sensor,
radiator,
timing chains (front & rear),
several coils,
plugs,
cleaned ABS sensors,
replaced front wheel bearings,
All new A/C system,
Need to replace worn CV shafts....
Need to replace worn rack & pinion....
Problem:
Service Stab System
Traction Control,
Reduced Power Mode
I am fixing to rip out this POS 5 cylinder and drop in an ls1, I just wanted to keep this thing original.
Won't clear codes anymore, TCM (throttle body) says it has a 2.5v (high reading, think it should be 0v) and the other reading is the 5v for it, chased all the wires, all seem good.
Sorry don't recall the codes right now, need to hook up the OBD and get back to you.
Any other suggestions?
Replaced:
speed sensor,
crank sensor,
PCM (once already),
camshaft sensor,
radiator,
several coils,
plugs,
All new A/C system,
Problem:
Service Stab System
Traction Control,
Reduced Power Mode
Olds & Hummerz,
Replaced:
speed sensor,
crank sensor,
PCM (once already),
camshaft sensor,
radiator,
several coils,
plugs,
All new A/C system,
Problem:
Service Stab System
Traction Control,
Reduced Power Mode
Replaced:
speed sensor,
crank sensor,
PCM (once already),
camshaft sensor,
radiator,
several coils,
plugs,
All new A/C system,
Problem:
Service Stab System
Traction Control,
Reduced Power Mode
Forgot to mention, a LS1 won't fit, not without a LH8 oil pan. And even then, you will have substantial steering geometry issues.
Vehicle: 2006 H3 3.5L basic (manual), 82K miles
Same issues: loss of power, traction failure light comes on. Also noticed mpg dropped from 13 city to 7 city and exhaust smell continuous during operation.
April 2016 Mechanic pulled codes PO101 MAF sensor, PO326 Knock sensor and PO068 Throttle body. Examination found catalytic converter had broken and was choking engine exhaust. Replaced catalytic converter and downstream O2 sensor (437 converter, 130 O2 sensor, 3 hours labor @ 89/hour total 834). Car back to normal and still running no issues Dec 2016.
Not sure you have exact same problem, but seemed similar.
