2006 H3 Hummer Water Soaked Interior
Old Nov 17, 2019 | 05:30 PM
Lolason's Avatar
Default 2006 H3 Hummer Water Soaked Interior
My H3 was waiting for a new Motor and the sun roof started leaking and completely ruined the interior. I'm concerned about mold behind the dash board and about residual odors if I were to try and restore it. Does anyone have any experience with this...or suggestions?
Old Nov 17, 2019 | 05:52 PM
Before mold remediation can begin, any sources of water or moisture must be addressed.
Old Nov 17, 2019 | 06:26 PM
wpage's Avatar
Agree find out and remedy problem. Then follow SOP for drying and refreshing interior. Its standard...
Old Nov 18, 2019 | 01:50 PM
Google how to fix H3 hummer leaking sunroof. Same procedure for many vehicles give or take, clean out the sunroof drains, modify the tube ends by cutting out the X, then dry out. Pull the vehicle inside, pull out carper and insulation, blow warm dry air at it. Do not put back together until completely dry.
Hope you did not toast the BCM when you failed to address the sunroof leak. Usually the problem, odor and mold............ not so much
k9guy
Apr 26, 2012 05:33 AM
Dawgfan1981
Nov 15, 2011 09:44 PM
small dave
Apr 22, 2010 07:27 PM
leebo316
Apr 2, 2010 12:57 PM
valleysniper23
Dec 9, 2009 10:45 PM
