2006 H3 Full Frame off restoration with new frame
Old May 21, 2023 | 09:07 PM
CarGuy91's Avatar
Talking 2006 H3 Full Frame off restoration with new frame
day after purchase
its such a nice rig
1 month after purchase finding out about frame
if you love it spend enough money where your wife questions what you love more
new frame painted treated and show lots of love
Old May 21, 2023 | 09:24 PM
CarGuy91's Avatar
Hi guys figured this would be the best place to start with needing information.
Details on Build
2006 H3 with the 3.5 180k miles originally from mass now in Maine ran great except oil leak caused from stuck pcv and a HOLY Frame "rusted out" Frame and Motor are both being replaced a 3.5 from a 2005 canyon 5 speed 4x4 that had 43k miles on it as far as i know the Atlas inline 5, 3.5 is the same across all vehicles. Frame is from a 2007 H3 From the south no rust dings etc.
My goal is to have a near flawless H3 with no rust, suspension, or engine issues would love to lift it but im on a VERY tight budget Part donations are welcome!!
! very much would have done a Alpha conversion but finding one and then having to do all the electrical it would make more sense to just buy an alpha, also debated on putting in the 3.7 however there are no 07 h3 engines and ecu in my area for sale at a decent price they want upwards of $2k for the motor
Would love to install a 2.5 to 4 inch Suspension Lift and 1 inch body lift but budget wise i may only be doing the 1 inch body lift
every single part that came off that's going back on is being sand blasted, Treated, and Painted (HVLP) with Kbs possibly another black high temp paint for the Knuckles and Calipers
where it is currently
Body is in the air underside has been sand blasted, treated with kbs cleaner, kbs rust converter, and then HVLP sprayed with kbs rustseal 2 coats both about 1.5 mil thick then 2 coats of blacktop 1 mil each looks brand spanking new
Old frame was disassembled cut in half and then junked it was not even worth saving
new frame was from the south no scaling rust just surface however i sand blasted it anyways and did the same as the under body with kbs looks like a brand spanking new frame i want to get stickers for it if anyone knows how to get them
what i need help with
1) i need to find every single bushing, sway bar link, dust shield, and all other parts that are wearable items on a hummer h3 frame here is my current list but i feel like im missing things
Here is a list of parts that i assembled ****im assuming all positions****
Rear of H3
shackle kit- 722-083 *does this include the bushing for the leaf spring or the bushing that goes into the frame? feel like its for the leaf spring
Leaf bushing (Rear to Frame)-K200802 *rear to frame bushing*
Leaf bushing (Front & Rear)-RB172DAY *bushing that goes into the leaf spring*
Sway bar link-K750243 *Rear sway bar links*
Sway bar bush-K201548 *Rear sway bar bushings
Front of H3
Control arm bush-K200155 *lower control arm bushing Rear By torsion bars*
Control arm bush-15088366 * Lower control arm Pressed into Frame*
sway bar bush-K201407 *Front sway bar bushings*
Sway bar link-K750185 *Front sway bar link*
Dust Shield Left-25907221
Dust shield Right-2590722
Hub assembly-515093 * Hub assembly replacing both wheel bearings*
Upper Control Arm pass-19354097 *passenger upper control arm*
Upper control arm Driv-19354098 *Driver upper control Arm* !!!!! I cannot seem to locate just the bushings for the upper control arms!!!!!!
some parts i still need to find are
front diff cover
rear diff cover
EGR line from box to quick disconnect
A list of all bolts
im sure im missing a few parts i should replace please let me know and add what it is and possibly a part number for me to look up
I have used reflex shocks to put on rather newish
torsion bars and keys are original 180k miles ** should i replace them** if so are there interchangeable parts from other cars i can use
4 speed auto transmission and transfer 180k inspecting gears and replacing fluid, transmission still has cherry red fluid
No singular person knows everything and a a collective we know it all so all information you can help me with would be an astronomical help i consider myself a jack of all master of none but still better then a master of one
I have all the tools except for a metal bender or the ability to machine parts
seriously part donations would be incredibly helpful
Old May 26, 2023 | 03:55 PM
650Hawk's Avatar
Just to clarify things, your only options to lift it are a 1" (or 1.5") body lift, or find an old Rancho 4" lift (hasn't been manufactured for a number of years now).
Old Jul 1, 2024 | 07:12 PM
Hungrydingo's Avatar
Did you ever get this finished? I’m in Sebago Lake area and want to do something similar. I can’t message you so feel free to message me if you dont mind
Also I know of a bunch of used parts locally if you need any
dougyb
Feb 22, 2022 06:53 PM
UcraDen
Nov 20, 2020 10:41 AM
vetteman40404
Mar 30, 2010 04:48 PM
jdrew
23
May 4, 2008 10:00 AM
MarkM
25
May 6, 2006 06:15 PM
