-   Hummer H3 (https://www.hummerforums.com/forum/hummer-h3-17/)
-   -   2000 RPM Rattle/Vibration Noise (https://www.hummerforums.com/forum/hummer-h3-17/2000-rpm-rattle-vibration-noise-38161/)
user 956363738 Apr 2, 2017 03:42 PM
Hey guys,
So I researched common causes for this annoying vibration noise from 1700-2100 RPM. Took off the heat shield on the exhaust manifold (the bottom bolt near the O2 sensor has been broken off for some time), but the noise still occurred. I then took off the front skid plates, noise still occurred after that. Checked the heat shield on the exhaust toward the rear of the H3 and one of the original clamps broke off, so I installed a new clamp around it, and that did not fix it either.
The sound seems like it is coming from the undercarriage under the front passenger seat.
Does anyone have any other suggestions to fix this noise?
Thanks!
TAINTER Apr 3, 2017 02:41 AM
You have checked everything I can think of except for the resonator/muffler directly under the pass and seats. Had a issue with a price on the inside that came loose. Tap on it and see if you can hear a rattle there.
Paranormal Apr 3, 2017 07:22 AM
Check to see if your catalytic converter is shot. Sound travels, also check your jack and tool bag in the rear door. Check bolts for seats. I once had a rattle that I swore was in the front and it turned out being that same, small heat shield that you fixed on the upper loop of the tail pipe.
cucumber1949 Apr 3, 2017 09:08 AM
I found a broken weld on my heat shield as shown in the attached, under the passenger side seat, causing a tinny rattling noise. The 'fix' was a worm gear clamp.
Service Bulletin: Under Vehicle, Heat Shield Rattle (2007-2008 Colorado Canyon) - Chevrolet Colorado & GMC Canyon Forum
After that, a new rattle became more prominent, which turned out to be the fan clutch. Replaced water pump, fan clutch, and while it was apart, put on a new idler and tensioner and replaced lower hose. No more rattles/noises.
DraxHummer May 24, 2017 07:40 AM
I just did this same repair with water pump, fan clutch and new idler and tensioner. I am still getting rattles/noises. I'm going to check the heat shield.
I did have the heat shield fixed once before.
THertner Dec 29, 2019 11:26 AM
Love your truck Paranormal, more pics anywhere?
Doc Olds Dec 31, 2019 09:43 AM
Digging up 2.5+ year OLD Threads to ask for pics? Oh boy......
https://cimg0.ibsrv.net/gimg/www.hum...ea4749ea57.jpg
THertner Dec 31, 2019 01:11 PM
Running around kicking everyone, not as saavy as yourself, is like condiscending bullying. You do it to EVERYONE. And god forbid we don't have the same views as you. Would you rather I stay a lurker, or will you lighten up? NO one with any style has your same views. I am being 100% serious right now. Take it or leave it.
hummerz Dec 31, 2019 01:23 PM
https://cimg8.ibsrv.net/gimg/www.hum...39e48ac90e.jpg
