180 Degree Thermostat for the H3? and Jet Chip?
Old Feb 24, 2008 | 12:45 AM
jandmtv's Avatar
Default 180 Degree Thermostat for the H3? and Jet Chip?
hi guys, i want to get a stage 2 Jet Chip module for my h3, but the stage 2 asks for free flow exhaust, which i have, and a 180 degree thermostat to be installed.
i have searched high and low and cant find a 180 thermo. for the H3, i found plenty for the H2 though.
here is a link to the jet module
http://cgi.ebay.com/Jet-Chip-Module-...QQcmdZViewItem
also, does anyone here have a jet chip module installed on their h3? was there any noticeable difference?
thanks
Old Feb 24, 2008 | 06:08 PM
GarrettMoore's Avatar
Default RE: 180 Degree Thermostat for the H3? and Jet Chip?
My guess is that their "Stage 2" simply further advances timing and leans out the mixture, thus increasing cylinder temps, and their suggestion of a 180 degree thermostat.
Since you can't find the thermostat, I would imagine equal, if not better results could be achieved with a bottle of Watter Wetter and 1 heat range cooler spark plugs.
Old Dec 2, 2009 | 03:18 PM
majaloke's Avatar
Your Hummer already has a 185 degree thermo, so you don't need to change it. I installed the stage 2 Jet chip, I have a Gibson cat-back exhaust and it makes a real difference, especially at 3000 rpm and above.
Old Dec 2, 2009 | 05:20 PM
marksteven's Avatar
I am also considering the jet but stage 1. Did you notice any power gain. I just put 315 tires on my H3 today.
Old Dec 2, 2009 | 09:19 PM
Chips = old/outdated technology.
Go with a PCM tune, instead of trying to "trick" your PCM by altering the actual sensor input information, you can custom tune many variables based upon what is actually happening.
A Tstat change to a lower temperature will also place a heavy load on your cooling system leading to premature failure and higher auto trans temps, also leading to premature AT failure.
Also, a PCM tune will recalibrate your speedo to larger tires, and keep AT shift points at the proper RPM point to maximize the performance increase by keeping you in the peak power band longer, something chips cannot do.
I have used Jet chips and Tstats years ago on many trucks, PCM tunes are a big improvement over the chip set ups. IMHO when you do a price comparison, no brainer.
Old Dec 3, 2009 | 10:14 AM
2wheelmonster's Avatar
Do you suggest a certain place to get a PCM tune?
Old Dec 3, 2009 | 11:02 PM
dlinden200's Avatar
Wink
I would guess 'Doc Old' sells them due to his high praise of them.
But on the serious side, I do not have the PCM, but am going to get it because of all the other high praise.
Just do a search for "PCM".
Old Dec 4, 2009 | 06:18 AM
D VADER's Avatar
PCM4less.com. Talk to Kelly.
Old Jun 2, 2011 | 06:17 PM
ArizonaFeeds's Avatar
I have not installed the K&N filter yet. Can I put the Stge 2 chip in now with the stock intake? I5 3.7 engine.
kmleong
Sep 12, 2024 12:26 PM
Caraddict
Aug 30, 2011 09:02 PM
Daveleach
Aug 8, 2011 12:10 PM
DirtyH3
Nov 10, 2010 12:55 PM
mtauseefsa
Aug 27, 2010 04:48 PM
