'07 Power Steering Fluid Leak
Old Jun 10, 2020 | 08:58 PM
MarkMc00's Avatar
Default '07 Power Steering Fluid Leak
I have a constant drip of PS fluid where the hoses from the PS pump connect to the steering gear (or rack and pinion). I can't find any reference to power steering hose seals at the parts stores. Can someone tell me what the seals look like, where I can get them, and if it is a difficult job to replace them? Is the same seal used for both hose connections? I can access the area easily enough (once I rotated the fan shroud out of the way). I tried tightening the bolt securing the hold down plate, but the drip seemed to get worse. I attached a picture showing the connection.
Thanks for any advice you can give,
Mark
Old Jun 11, 2020 | 06:50 AM
There is 1 O-ring on each of the tubes.
I'm not sure of their diameter or thickness but I have replaced one after loosing it while swapping out a new rack.
Old Jun 11, 2020 | 09:32 AM
You asked for it.....
Old Jun 11, 2020 | 09:49 AM
MarkMc00's Avatar
Ha! I did ask for it!
Old Jun 11, 2020 | 09:56 AM
MarkMc00's Avatar
Do you remember where you got the replacement o-ring?
Old Jun 11, 2020 | 10:11 AM
Broken Halo's Avatar
You can get a whole kit that would probably have your size in it at Harbor Freight for only $7.99 ($6.40 with coupon)
https://www.harborfreight.com/382-pi...ent-67554.html
Old Jun 11, 2020 | 10:36 AM
You can also go to your local parts store, they have a kit that they will sell by the piece. .29x.44 x.07 size RockAuto
Or as BrokenHalo stated, buy a whole kit also available on
Amazon Amazon
Old Jun 11, 2020 | 10:47 AM
Sorry, my neighbor had a huge assortment kit in his HVAC work truck. I miked the diameter and thickness and we found it.
Old Apr 28, 2021 | 11:34 AM
Falba93's Avatar
@TAINTER Do you remember which size the o-rings were? A friend of mine does HVAC too, I also have a set of black ones(std. sizes) I got a few years ago.
Thank you.
Old Apr 28, 2021 | 11:57 AM
wpage's Avatar
When you change it out. Go like for like on the O Ring...
