07 L5 3.7 engine installed in a 09 hummer h3 3.7 09
I put the 07 3.7 engine in my 09 h3, now it don't start right, and runs rough down the Hyway. I know that the actuator is different between the 07, and the 09 engine. I rebuilt the 07 engine, then installed it in my 09 h3. I got a new position actuator sensor, and wired the 07 plug on my 09. Didn't make any difference. Will have get the computer reprogramEd? Thank you for any help!
with a good scan tool or a tech2 do a crankshaft relearn.
Relearn?
(Post 388557)
you need a good scan tool or a GM tech2 scan tool... it would be in one of the option menus
Isnt the 2007 engine a 24x and the 2009 58x? I cant believe it is even running at all!
07s and 09s use different PCMs, your 09 PCM is not programmed to properly run the 07. I have heard many will run, but not like they are supposed to. You need some programming.
Xs 2 what atvspeed4 said. |
"2007 engine a 24x and the 2009 58x" What does that even mean?
Reprograming
(Post 388584)
The '07 uses a different CKP vs the '09, yet both are 58x.
https://cimg9.ibsrv.net/gimg/www.hum...b69e489187.jpg |
Originally Posted by Justinh
(Post 388591)
