07 hummer h3 transmission compatible
Old Jul 5, 2024 | 07:42 AM
Metal4Life's Avatar
Default 07 hummer h3 transmission compatible
06 colorado 4x4 transmission compatible with the 07 hummer h3?
Old Jul 8, 2024 | 02:31 PM
brothapig's Avatar
You will at least need your old pan. There is a cut out on the H3 tranmission pan for the front drive shaft.
Someone else will need to speak to the electrical compatibility.
Old Jul 9, 2024 | 08:55 AM
Why do you need a swap? Rebuild the Trans you already have.
An 06 Colly 4L60E will work in an H3 so long as you make sure to use the correct pan. I thought I recall something may be different in the Valve Body as well so check that out.
Shaun turner
Sep 11, 2023 10:39 AM
Mammoth H3
Jan 22, 2023 04:06 PM
rhill20
Sep 12, 2014 04:53 PM
flatlandbob
Aug 6, 2010 03:40 PM
VanSmite
Nov 29, 2007 07:54 AM
