'07 / '08 / '09 OEM H3 rims on an '06 H3
Old Jan 21, 2020 | 11:23 PM
Cruize's Avatar
Default '07 / '08 / '09 OEM H3 rims on an '06 H3
I have a base model '06 H3 w/ 265/75/16 tires and I am looking at getting an extra set of OEM rims. From www.wheel-size.com, the rim size for the '06 is 8.5Jx16 E25. For the '07, '08, and '09 with the same 265/75/16 tire size, the rim is listed as 7.5Jx16 ET38.
The back spacing should be the same, I think.
'06: 8.5" rim width / 2 *25.4mm/in + 25mm offset = 132.95mm backspace.
'07 - '09: 7.5" rim width / 2 *25.4mm/in + 38mm offset = 133.25mm backspace.
Can I run an '07 - '09 rim with the 265/75/16 tires on my '06 without any problems?
Thanks in advance
Old Jan 22, 2020 | 07:14 AM
2006-2010 H3s & 2009-2010 H3Ts ran the exact same 16" wheel size 7.5"x16".
Can't believe everything you read on that there internets. Not sure why that website has it wrong, but they do.
Any 06-10 OEM 16" wheel will work for ya.
There where 18" wheels on the H3X and other 18" & 20" wheels from GM Performance parts for the 2006-2010 H3s & 2009-2010 H3Ts.
Old Jan 23, 2020 | 11:05 AM
MOVED this for you, ain't nobody posting in the old Tire and Wheel section. Put all the H3 related stuff in the H3 section where there is some traffic.
X2 what Taint said. Get yourself some tires, those 265s look like hockey pucks on an H3.
Fondo
Sep 11, 2018 10:31 AM
ekbruster
Jan 12, 2013 03:20 PM
YTH1
Feb 12, 2008 04:46 PM
hockeymutt
Jan 12, 2008 05:04 PM
whododat
Nov 22, 2006 03:55 AM
