06 h3 instrument cluster dead
Old Nov 10, 2009 | 11:09 PM
bigec's Avatar
Default 06 h3 instrument cluster dead
Started up my h3 today and the entire instrument cluster was dead. Truck still ran fine just no gauges worked. Turn off and on many times still same. One final try and everything worked fine. Any clues what is going on here??
Old Nov 11, 2009 | 08:27 AM
DAGKANA's Avatar
You probably have a loose fuse, or a dead one. Its a simple 20GA fuse I believe, could be a 10GA. Pop your hood, take the cover off your fuse panel and look for cluster on the underside of the cover, pull the fuse and put a new one in
Old Nov 11, 2009 | 07:58 PM
2wheelmonster's Avatar
When it went off did it stop recording the mileage?
Old Nov 11, 2009 | 11:26 PM
bigec's Avatar
Didnt move the truck so no mileage was added. Has been working fine ever since. A real mystery to me
Old Aug 13, 2022 | 03:29 PM
KAndrew's Avatar
Default Solved
The issue I found was the firing wasn’t locked into the bottom of the fuse box.
Pull the fuse box out and there is two harnesses cam locked into the bottom side. Neither one was locked in but the fuse box was locked in on the driver side the side closest to the engine wasn’t all the way down. Was hard to find!!! Had to wiggle the wires a ton to find it.
Old Aug 15, 2022 | 11:41 AM
Who are you talking to from THIRTEEN YEARS AGO?????????????? READ: Old Threads/'Necro-Bumping'
JakesSUT
Aug 8, 2012 10:16 AM
dwaxman1
17
Mar 27, 2008 04:20 AM
hmmrgrl
Nov 30, 2007 11:15 PM
hmmrgrl
31
Nov 15, 2007 05:39 AM
rlbock
Oct 17, 2007 12:35 PM
