Hummer H2 SUT For some who need the usefulness of a truck, but do not want to compromise the Hummer look, the H2 SUT does just that.
SUT carpet options
Old Dec 8, 2022 | 05:05 PM
Lifestyle's Avatar
Default SUT carpet options
Does anyone know if either the 2002-2006 Cadillac EXT or Silverado Crew Cab carpet fit the H2 SUT?
they make every custom color in the world for those trucks and nothing particularly for the H2.
the seats and consoles, floor mats, etc. are all compatible.
Old Dec 8, 2022 | 08:54 PM
Lifestyle's Avatar
Old Dec 9, 2022 | 09:20 AM
Where do you get that the seats, consoles, floor mats, etc are all compatible???? Can you show us an H2 with Silverado seats and center console installed (and just bolt right in?)? I'm thinking totally different body, floorpan, etc means that none of that will work. Electrically the seats would function but I sincerely doubt that the actual brackets would work.
Old Dec 9, 2022 | 10:31 AM
the hummer is a wider truck than either the escalade or taho so the carpets might come up short width wise
Old Dec 9, 2022 | 10:42 AM
Lifestyle's Avatar
I meant comparative as in there the same seats, console wise, no the others won’t bolt right in and line up with out dash and panels but the corresponding years are size similar, similar being the example.
I didn’t know if the belly panels were close enough to give the options of trying to use other models like the EXT or Silverado Crew Cab carpet with only minor modifications being that you can get every color imaginable for those models through ACC but they don’t have nothing for the H2 for whatever reason.
I thank you both thow, I did hear once before that the SUT is something like 4” wider.
Old Dec 9, 2022 | 12:03 PM
Yes width would def be an issue on carpet from something else. I ran into that when I had my headliner redone.... no place local stocked headliner material wide enough to do it in one piece (SUV). They could special order a wider roll but would not be worth ordering an entire roll to do one headliner. I changed it up and had them do it custom sewn two tone which worked out nice.
Old Dec 9, 2022 | 03:21 PM
Lifestyle's Avatar
Yah I think getting an interior shop to custom make a carpet in the color I’m looking for is gonna most likely be the best route. Thank you for the good information.
Old Dec 23, 2022 | 03:05 PM
finall's Avatar
Auto Custom Carpets if they are still around. Biggest in the industry.
Wraypau
Hummer H2 SUT
Sep 19, 2021 01:06 PM
finall
Sep 27, 2009 01:38 PM
HummBob
21
Jan 3, 2008 12:36 PM
Doc Olds
Dec 23, 2007 07:34 PM
