SUT carpet options
Does anyone know if either the 2002-2006 Cadillac EXT or Silverado Crew Cab carpet fit the H2 SUT?
they make every custom color in the world for those trucks and nothing particularly for the H2.
the seats and consoles, floor mats, etc. are all compatible.
Where do you get that the seats, consoles, floor mats, etc are all compatible???? Can you show us an H2 with Silverado seats and center console installed (and just bolt right in?)? I'm thinking totally different body, floorpan, etc means that none of that will work. Electrically the seats would function but I sincerely doubt that the actual brackets would work.
I meant comparative as in there the same seats, console wise, no the others won’t bolt right in and line up with out dash and panels but the corresponding years are size similar, similar being the example.
I didn’t know if the belly panels were close enough to give the options of trying to use other models like the EXT or Silverado Crew Cab carpet with only minor modifications being that you can get every color imaginable for those models through ACC but they don’t have nothing for the H2 for whatever reason.
I thank you both thow, I did hear once before that the SUT is something like 4” wider.
Yes width would def be an issue on carpet from something else. I ran into that when I had my headliner redone.... no place local stocked headliner material wide enough to do it in one piece (SUV). They could special order a wider roll but would not be worth ordering an entire roll to do one headliner. I changed it up and had them do it custom sewn two tone which worked out nice.
Doc Olds
Dec 23, 2007 07:34 PM
