Hummer H2 SUT For some who need the usefulness of a truck, but do not want to compromise the Hummer look, the H2 SUT does just that.
Onstar display
Old Oct 2, 2019 | 04:26 PM
countrywild56's Avatar
Default Onstar display
I purchased an 07 SUT several months ago as a total and have been restoring it. I am almost done and am replacing dash components. My question is when the key is on and the engine is running should the front Onstar panel be lit up like the a/c module? Mine is completely dark. I need to know if this is another component I need to replace to make everything original. Thanks for the help!
Old Oct 13, 2019 | 03:21 PM
coffeydp's Avatar
Did you check the fuses? A lot of folks pull the fuses on the Onstar units.
Old Oct 13, 2019 | 05:22 PM
Default Bad unit
Thanks for the info but it was a bad module. I replaced it and it's good now. Thank you!
Ken06H3
Sep 28, 2011 03:08 PM
spikemorrison
Aug 8, 2010 05:53 AM
stefan
Jul 16, 2010 03:04 PM
dunringil
May 4, 2010 02:58 PM
HummerGuy
20
Oct 14, 2007 02:07 AM
