2005 Hummer Sut Project
Model # 6045, no housing needed, they actually screwed into the factory housing.
Headlights are from Same Company, Model # 6130.
As you know the fog lights are set-up for driving lights from the factory, but i actually had them switched so i could control them
That was the first thing I noticed - how did you do this? Run all new wires with a switch, or is there something easy to tap into inside the cabin? Seems like there should be an easy place to tap into that replaces the current automatic on/off with a switch, I've just never looked into it.
Yes Skeptic, they ran all new wiring and installed the switch under the tow button, I had a blank spot there. They Installed the switches for the Light bars between the center vents on the dash, I will post pics if you want to see.
Since truck has been lifted I could not see at night with the factory headlights, what a difference with the new HID lights, dont have to worry about running over someone!
