Will chevy 2500 lift fit on H2???
Old Jan 13, 2021 | 02:53 PM
Beto1215's Avatar
Default Will chevy 2500 lift fit on H2???
Hello i had a question i currently have a 3inch torsion key lift ...i want a 6inch lift ...but they are very high dollar still, so my question is being that the front end of the h2 is a chevy 2500 will a 6 inch front end component lift work on my H2 and then just run lift blocks in the rear ???? Its like half the cost of a lift for a H2 ???????
Old Jan 13, 2021 | 06:08 PM
My question, do you feel lucky? If so, make sure to have full coverage auto & life insurance, before you drive, after completion.
Old Jan 14, 2021 | 06:35 PM
coffeydp's Avatar
hahaha, yeah I wouldn't drive it, and I swim with shark on the reg!
Old Jan 15, 2021 | 07:44 AM
tharber's Avatar
The Hummer H2 frame is not the same as any other truck. It's similiar but that's why you see such a huge price difference. If anything it's closer to a Suburban. You might get away with torsion lift and then add a body lift on top of that.
Tim
Old Jan 15, 2021 | 08:54 AM
Generally speaking the front suspension is identical to a GM 2500 SUV and the rear a 1500 SUV but I'd still double check everything to be 100% sure. One way would be to look at part numbers and vehicle fitment / interchange part numbers for many of the various parts. I think you will find that for example a Moog UCA for a 03-07 H2 is the same part number for a 03-07 2500 SUV. It is not always easy to really be sure though and some parts like welded brackets would not be as easy to determine for sure. One example - upper control arms. https://www.1aauto.com/chevrolet-gmc...q/i/1asfu00042
According to 1A Auto the same UCA fits pretty much all GM HD trucks and the H2.
The problem is some are not as easy to find and be sure of and lift lit manufacturers who have made kits specifically for the H2 have already done the research and/or made 100% sure while ones listed specifically for a GM truck they may or may not have...
D'Narius Connor
Mar 30, 2020 10:11 AM
Hmmer
Mar 24, 2013 09:17 PM
Nxsov180db
Jun 22, 2008 08:50 PM
kouvelis888
Jan 25, 2008 11:50 AM
RedRocker
May 19, 2007 07:49 AM
