Will 37/12.50/17's fit on a stock H2?
Old Jan 8, 2023 | 04:04 PM
PA05H2's Avatar
Default Will 37/12.50/17's fit on a stock H2?
I have four, barely used 37/12.50/17's in my garage all mounted and balanced. I'm wondering if these will fit on my stock H2 that right now has 315/70/17's on it (no suspension lift, no body lift, nothing) . I do know that the 37's are a little over 2-1/2 inches larger in diameter which will reduce the clearance between the tire and the wheelwell by around 1-1/8 inches. I know I could just go put 'em on and find out, but that's a lot of work and I thought I would check with the experts first. My inclination is that they will fit, but it's likely that I would need to be careful when turning near lock to lock.
Thanks!
Old Jan 23, 2023 | 11:14 AM
I don't know about 37s being 2.5" larger diameter than 35s, as it would depend on tire brands and models being compared.
However................... yes, I know many H2 people that run 37s. The old Tire & Wheel section is dead, keep your H2 related questions over here. Let's see what others say.
Old Jan 23, 2023 | 12:04 PM
zenith's Avatar
I'm guessing they'll fit just fine. I'm running 37/13.50/20 on my 07 stock suspension. I get a small rub on the front sway bar when turning with locked steering. My wheels are factory 09 H2 20" wheels.
Here's a great tire size calculator you can use for all tire size comparisons.
https://www.tacomaworld.com/tirecalc
Old Jan 24, 2023 | 03:47 PM
Booch's Avatar
Yes they will fit fine , I have the same size
Old Jan 25, 2023 | 07:59 AM
PA05H2's Avatar
Thanks Doc Olds, zenith, and Booch. Just what I was looking for.
Old Jan 26, 2023 | 09:32 AM
HellHoof's Avatar
I have 37 x 13.5 x 24 and they rub on the fender liner when I turn them most of the way, or if I pull into a driveway at speed while turning (as the truck bounces up/down). It's not so much that I have done any trimming on the plastic - I just live with it.
Old Jan 26, 2023 | 11:36 AM
Gavin Costigan's Avatar
I have 37x12.5r20s on stock suspension and they only rub on the fender liner at full lock and hitting a large bump. I have the inner inside corners detatched from the clip and held with a zip tie for a little more room, but yes they fit just fine.
Old May 25, 2025 | 10:50 AM
SHOCKTROOP40's Avatar
Hello. First, Happy Memorial Day weekend. Second, did you have the re-gear the axles to accommodate the 37inch tires?
Old May 25, 2025 | 11:06 AM
zenith's Avatar
I did nothing yet. My speedo runs about 3-4mph faster than my actual speed according to my GPS.
Old May 25, 2025 | 11:17 AM
I appreciate the reply. I am planning on putting 37's on my 09 H2. I had a 05 H2, in which the previous owner already installed a lift kit on her with 38 x 113.50 R22 tires. I wasn't sure if the previous owner re-geared the H2 or not, but she didn't struggle at all going up steep hills and overpasses.
