When the gear get stuck and shifter moves freely
It happened this Friday on the Florida keys 130 miles away from home in a road to non-where with very little traffic at 9 AM
After hit a bump while making a 3 point to come back the trans got stuck in Drive , Truck turn off and when trying to start it it just shoot off like it was having a short circuit ... shifter moves freely up and down
Well after an inspection on the shifter determined that wasnt the problem .
A quick inspection below the truck shows a pin with a plastic clip holding the bar which runs to the trans and shift ( Driver side just below the door) . The plastic clip was broken in pieces ... Fixed with a rope and made it to home ...
I just want to let you know this part is very prone to break so check it every while ..
BTW Autoparts bushing kit doesn't fit to the H2 .
I will go the dealer tomorrow and ask for a better replace for this , maybe metal or any durable plastic ...
If you know any way to fix it , please let me know
Gm wont sell only the bushing for the repair, they sell the whole wire for $100 ish , bad part design and not easy/cheap replacement. Always the same. And dont bother with the autoparts bushing kit , it wont fit
OK As I post it before the plastic bushing that hold the shifter cable to the trans break as I found to be a very common issue I was thinking instead of replacing the whole cable for a OEM new , I will try to fix it and maybe comes even better ...
What do you expert think .
1- Removing the brake
2- remove the link with the small ball
3-attach a screw
4-use a bushing kit from autopart to cover the space between the cable head and the screw , also to make smooth transition for the shift
5-lock nut to hold the cable in place ...
This way even if the bushing break the shifter cable will still be connected to the trans . preventing the truck to got stuck in one gear
Opinions welcome
3-attach a screw
Opinions welcome
Thank you for posting this. My H2 just did this to me today but luckily it was parked at home. Went to run out and started the H2 when I put it in gear the shifter moved really easy but the transmission stays in park. I checked the upper connector under the shifter and it’s still connected so now I will check the connection at the transmission tomorrow morning because it’s pouring outside right now and it’s after midnight. My first thought was the shifter cable was broken but before I call my mechanic I will check the under connection first to save some money. I have the skid plate and not really enough tools so I hope I can get to this without having to remove it. I’m disabled and not really mechanically capable of fixing anything serious on vehicles but watched a video and it seemed pretty easy to fix if I can get to it. (2004 H2)
Yes. I had to order the bushing from Autozone so went ahead and got 2 packs so I have 1 spare ready if it happens again. Thanks
hummer_on_fumes
Jan 27, 2018 11:01 AM
chip4065
Mar 30, 2012 09:27 PM
