upgrading stock lighting in front end.
Old Oct 23, 2013 | 12:47 PM
H2CANEPADESIGN's Avatar
Default upgrading stock lighting in front end.
So after changing out the front lights with a 6000k hid set up (low beams only) and swapping the bulbs in the drl's , Ive noticed a lot of fogging on the lenses. I used a headlight lens restoration kit to no avail and also removed the housings entirely and washed the dust out of the inside of the housings...both drl's and headlights.
got fed up with it all today and ordered
Amazon.com: Delta 01-9029-50X Fascia Driving Light Kit for Hummer H2/H3: Automotive Amazon.com: Delta 01-9029-50X Fascia Driving Light Kit for Hummer H2/H3: Automotive
to convert the drl's into fog lights, and
to replace the headlight lenses.
Will install this weekend and I'll keep you posted on the difference if any.
Old Oct 23, 2013 | 03:55 PM
LoJac963's Avatar
is this what you're talking about?
Old Oct 23, 2013 | 05:15 PM
FLATLANDER's Avatar
H2CAN,
I cant find any specs on what you are linking....can you provide a littl more info as I am rebuilding..er upgrading my front end too..
Old Oct 23, 2013 | 09:10 PM
Nate2106's Avatar
Idk if that's his problem. But its mine!! lol
Old Oct 24, 2013 | 12:14 PM
Yes, mine is less condensation and more discoloration. I actually took the whole assembly apart and cleaned it out. my problem is in the glass or plastic itself.
Flatlander; the headlight assemblies are made by ipcw. they are the "crystal diamond pie cut headlamps". The DRL replacement that changes them to fog lamps is made by delta. the come with a wiring harness, switch and relay. Im going to wire them into the off-road light switch on my headliner.
Ahh, got lights just now. gonna have to pull the brush gard and grille off. oh boy. will do it this weekend.
Old Oct 24, 2013 | 05:57 PM
LoJac963's Avatar
These were what I put in mine after some small modifications to them:
They are insanely bright and were only $60 on fleabay. I had done a lot of research into the Delta's and the different kits they offer but the install and price was a huge deterrent.
You can take a look at my build thread for more info on the LED's I installed. They function the exact same as the stock DRL's but without the nasty looking stock housings.
Old Oct 24, 2013 | 06:04 PM
LoJac963's Avatar
I guess I don't have a build thread on this particular site but I did make a post of the install so here it is:
https://www.hummerforums.com/forum/h...stalled-30688/
Old Oct 24, 2013 | 06:42 PM
calif phil's Avatar
Great job. I like it.
Old Oct 25, 2013 | 09:43 AM
Fastfill's Avatar
Default Delta fogs
I installed the delta fog hid conversion kit several months ago. The difference in lighting is amazing. I also converted my headlights to hid as well.
Old Oct 25, 2013 | 09:45 AM
Fastfill's Avatar
Default Picture
Here is a photo of the hid's at night
