uggh
Old Sep 6, 2024 | 02:03 PM
mrbill's Avatar
Default uggh
my 03 h2 leaves the fan running when ignition is off.
i pulled the fuse and the fan stopped but now thebrake light beeps like the emergency Brake is on.and the battery drains in a few days.
Old Sep 6, 2024 | 02:10 PM
maybe the fan speed control module bolted next to the fan in the airbox is shorted. put your fuse back in and unplug the module instead to see if you still have the issue.
Old Sep 7, 2024 | 08:05 AM
oceanbrave's Avatar
@mrbill
Few points:-
  • This is a classic Blower Motor Controller failure (Blower Resistor) this subject has been well covered in these forums.
  • You didn't mention which fuse you pulled out, but it should have been the 40A Blower fuse located in the LHS of the dash.
  • 100% agree with @bronxteck 's comments.
  • It's unlikely removing a fuse would cause more battery drain, also there's no connection/relation with the braking system, might this be coincidence or perhaps you disturbed something else?
  • Suggest unplugging the blower motor then putting the fuse back in.
Hope you manage to fix it 🫰
Old Dec 29, 2024 | 04:43 PM
NMH3's Avatar
BTW, PCM pinouts are shown in the "Engine Performance" section of the wiring diagrams I posted.
hunts4ducks
Jul 28, 2017 02:42 PM
Pacopatron
Dec 14, 2012 11:08 AM
Rooster
Apr 4, 2012 10:39 PM
CHP
19
Sep 15, 2011 08:00 PM
jrv mom
Oct 15, 2008 06:48 PM
