Transmission
Old Sep 29, 2021 | 04:14 AM
Brunner Ferdinand's Avatar
Question Transmission
Brunner Ferdinand Hello,
greetings to you,
My Hummer H2 Year of construction 2004 6.0 L
I rebuilt my gearbox and reinforced it.
Shifts flawlessly and great, but the converter lock-up lets my engine speed move up and down by about 200 rpm. Only when gliding.
The second thing is: if I turn up to 4000-5000 rpm, I have a short squeak when the 3 or 4 gear is engaged. Can someone help me there.
Thanks in advance.
Old Oct 1, 2021 | 07:09 PM
H2-SUT's Avatar
Sounds like the fluid clutch in the torque converter may have a problem or possible lockup converter solenoid is not functioning properly. A transmission shop should be able to identify the exact cause using an OBD2 tool such as a Tech 2.
How clean is your fluid, that is a good indicator of your transmissions health. You need to get it diagnosed as soon as possible.
Old Oct 4, 2021 | 01:32 AM
Hi,The gearbox was rebuilt.everything was reinstalled.
It goes up to 4500 rpm like a new gearbox.No errors are saved.
Doctor Umarov
Oct 26, 2020 08:57 PM
cesar23w
Hummer H1
Aug 2, 2020 05:05 PM
Alibou
Jul 2, 2020 03:16 AM
Rashid Iqbal
Jun 2, 2020 11:16 PM
Sarge1
Hummer H3T
Jul 29, 2019 12:55 PM
