Tail light
Old Feb 15, 2020 | 01:39 PM
Twilliams's Avatar
Default Tail light
My right tail light is off but the break light works on my 2006 h2. I heard it's most likely a fuse since I changed the light. Where is the fuse to the tail light located?
Old Feb 15, 2020 | 02:06 PM
check your ground for corrosion or wear at the chassis body mount located under the truck on the rear right side
Old Feb 15, 2020 | 07:40 PM
Take a "break", then check/clean the socket, test with lights on, brake light on, turn signal on. It's a dual filament, so make sure to replace brake light bulb with the proper bulb.
Old Feb 17, 2020 | 07:49 PM
hummer_on_fumes's Avatar
by "changed the light" do you mean you replaced a bulb or you swapped to led?
nijoma
Dec 17, 2013 07:49 PM
bhave232
Jul 11, 2012 04:10 PM
geeggee
Nov 20, 2008 09:24 AM
Black_Impala
Jun 3, 2008 11:18 AM
nascar 17
Mar 13, 2006 09:23 PM
