Supercharger Question
Old Jan 6, 2021 | 06:38 AM
snidly's Avatar
Default Supercharger Question
I am looking to install a supercharger on my 07 h2 but I cant find one to buy. Any ideas ?
Thank you.
Old Jan 6, 2021 | 07:35 AM
Look harder, do some research.
You have a GM truck with a 6.0 engine. Search for one for a GM truck instead of Hummer H2..... only difference might be you have to slightly modify the air intake or something but the engine, wiring, etc are the exact same.
Old Jan 6, 2021 | 09:57 AM
fastNYsix's Avatar
A turbo would be cheaper and easier. Also your trans probably wont last long. Like mixman said there's tons of info on this. I did an LQ4 turbo swap in my gbody. I can give you some tips and tuning advice if you go that route.
Old Sep 22, 2021 | 05:10 AM
snidly's Avatar
I finally found a supercharger and just finished installing it. What a difference it makes.
Old Sep 22, 2021 | 10:50 AM
what kit did you end up going with
Old Sep 22, 2021 | 01:15 PM
This is a friend's set up. It ate up three transmission rebuilds in 4 years, but he was never mellow on the pedal. I took the pic standing behind the open hood.
Old Sep 25, 2021 | 05:14 AM
snidly's Avatar
Vortech V-3
Old Sep 25, 2021 | 08:12 AM
legerwn's Avatar
how much boost are you making?
at what RPM do you notice the boost?
After I get my gears installed this is the next upgrade so I'm curious as many feel the centrifugal has lag and does not work on a heavy truck.
Thanks Neal
Old Sep 25, 2021 | 09:20 AM
snidly's Avatar
Boost Pressure is 8 - 9 PSIG.
At about 2500 RPM .
Even with 37's and a lift it drives great.
Old Sep 25, 2021 | 12:13 PM
legerwn's Avatar
Thanks for your response,
at 2500 its at 8 or 9 psi or the boost starts building at 2500 rpm?
Neal
