Steering Column replacement/upgrade 08
Old Nov 8, 2023 | 03:30 PM
Gavin Costigan's Avatar
Default Steering Column replacement/upgrade 08
It’s been a few months since I’ve replaced my steering box and pitman arm. I’ve still got maybe half an inch of free play when measuring the top of the wheel. I could narrow it down to whatever the joint is in the top of the column behind the steering wheel that allows for tilt and whatnot.
It’s only half an inch at most and maybe I’m being too picky but from videos I’ve seen of other trucks, this should be perfectly tight. I did the adjustment with the two screws an added some loctite, but it just comes loose again after a day. Also if I tighten it just enough so it doesn’t wiggle, if I tilt the wheel up or down it becomes hard to turn. This leads me to believe it’s just plain worn out.
Does anyone know of an upgrade solution or even where I could find a replacement?
video: https://youtu.be/X982CctqQYE?si=y4RbBAooLPa_Xv0T
File Type: mov
Old Dec 10, 2025 | 07:14 PM
Tom Tibortz's Avatar
[did you ever find a solution? I am at the same point as you are.
QUOTE=Gavin Costigan;404805]It’s been a few months since I’ve replaced my steering box and pitman arm. I’ve still got maybe half an inch of free play when measuring the top of the wheel. I could narrow it down to whatever the joint is in the top of the column behind the steering wheel that allows for tilt and whatnot.
video:
[/QUOTE]
Old Dec 12, 2025 | 04:43 AM
RobertDez's Avatar
Did you double check your lower steering column? The joint on it, plus make sure that pinch bolt where it connects to the gearbox is tight....
Old Dec 12, 2025 | 08:44 PM
[/QUOTE]
I tilted it where I wanted, used a lot of loctite, and dealt with it. I think this time the loctite held.
Old Dec 13, 2025 | 10:25 AM
SHOCKTROOP40's Avatar
Hmm, interesting. Thank God, my steering is nice and tight, but I've just had a custom lift kit installed in my 09 H2. Keep us posted on your progress.
Fast Eddie 1234
Mar 28, 2022 03:24 PM
DougH2
Jul 12, 2017 08:04 PM
Treviso
21
Apr 15, 2016 09:30 PM
jmamadog
Apr 5, 2011 05:27 PM
psych0
May 1, 2009 08:15 AM
