Service Air Suspension 2003 H2
Old Oct 25, 2018 | 06:53 PM
AlphaSwag480's Avatar
Unhappy Service Air Suspension 2003 H2
Hey guys & gals,
This morning when I was going to take the H2 to get washed and detailed, the "Service Air Suspension" message came on and the back end of the vehicle was riding real low. I parked the truck back in the yard and pulled my winch off the front and disconnected the power on the battery. I then checked the fuse, and that was good to go. When I hooked power back up and turned the truck on, the "Service Air Suspension" did not go off and I heard the compressor pumping. However, it was not getting any height. After reading through the forums, I knew to pull the key asap so the compressor didn't keep running so I didn't burn the thing up. When I inspected the air bags, there was absolutely dry rot and the passenger side air bag looked almost completely deflated, compared to the driver. So forgive me for asking, but do you guys think I just have a shot air bag and need to do a replacement? Here is the passenger side compared to the driver side:
Driver Side Bag
Passenger Side bag
Passenger Side Bag
Thanks for the advice in advance!
Old Oct 28, 2018 | 05:42 PM
Only way to know for sure will be to cut it back on and crawl under there and see if you can determine where the air is leaking out.
VBLocal89
Feb 21, 2025 05:15 PM
a_tperkins
Jul 24, 2016 11:01 AM
ninjarider
Mar 21, 2015 03:54 PM
Godwinrb
Feb 12, 2014 10:55 AM
davidtsx
Jan 26, 2010 07:08 AM
