Seat wiring?
Old Jan 1, 2020 | 10:00 PM
Urthworm's Avatar
Default Seat wiring?
Hello H2 community,
After driving a friend's H2 Hummer I realized the seats are awesome comfortable so I purchased a pair for my Overland rig build. The passenger side was simple for getting power to the main controls. Orange wire is hot and Black wire was ground. With these two wires hooked up I have all the seat controls working with the exception of the seat heaters. When I hook up the same wires on the drivers side the seat wont move. I notice that there are numerous plugs and am assuming they are suppose to plug into a control module of some sort for seat memory. Can anyone tell me if there is a box under the drivers seat that all these connectors plug into?
Also does anyone know how to bypass this memory system like the passenger side is?
Last question is does anyone have a wiring diagram for these seats?
If I can figure out the blues and pink wires on the pass seat then I can possibly rewire the drivers to match. Not my idea of fun but I really like the comfort of these seats and I paid dearly for them.
I would GREATLY appreciate any help I could get!
Thanks in advance!!
Old Jan 2, 2020 | 10:20 AM
yes the drivers seat does use a module. you will most likely have to follow the wiring on the passengers side to get the seat to work.
Old Jan 2, 2020 | 12:47 PM
Urthworm's Avatar
Thanks for the response. I watched a video on YouTube and can now see where the module used to be mounted. I'm going to have to find a used one. Can anyone tell me what the other wires for the main plug go to minus the 14g orange and black. Example: light blue, blue, pink, yellow, etc.?
Thanks Again!!
Old Jan 2, 2020 | 03:24 PM
I do not believe the module will work independently without the other supporting modules it connects to via the computer network.
Old Jan 2, 2020 | 06:07 PM
Looks like it should be pretty simple..... the attached will help you get it sorted out.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
JerzeyGirl
Oct 16, 2019 06:03 PM
canman
Nov 2, 2015 10:30 AM
Quijy
Oct 20, 2008 07:30 PM
atorreon
Sep 20, 2007 09:59 AM
skeeet
Sep 23, 2006 12:18 AM
