saggy rear
Old Apr 12, 2023 | 08:23 AM
hummerwalter's Avatar
Default saggy rear
2003 air inflater works, compresser does'nt come on to raise rear-end, replaced relay under mastercylinder. checked all fuses inside and under hood. idea's?
Old Apr 12, 2023 | 08:57 AM
Welcome to HF.
2003 what? Year, Model and Miles should be included in every question. This section, like it says at the top is not for Tech Questions, strictly intro. Once you share what your question is about I can move it to the vehicle section where tech questions go.
Old Apr 12, 2023 | 02:15 PM
Welcome to HF.
sorry. 1'st time. it's a hummer h2.
Old Apr 13, 2023 | 04:49 PM
oceanbrave's Avatar
As the tire inflator, this suggests the majority of the AS system is working e.g. ECU, Compressor, Airbag inlet valves.so not a relay or fuse.
Usually you'd get a "Service Air Suspension" message, however it seems some DTCs seem to be set without the message, particularly for the 2003
Might be worth getting it checked with a GM Tech2 scan tool, my guess would be a defective ride height sensor, hence the ECU doesn't attempt to inflate.
Have you tried operating the extended ride-height switch with the doors closed and engine running?
[Awaiting Resolution]
Old Apr 13, 2023 | 05:18 PM
yes. you are confirming my last guess. to the shop for a code read. thank you.
Old Apr 14, 2023 | 09:25 PM
ride-height wont work. agree with what you're saying. thank you.
Old Apr 26, 2023 | 06:40 AM
oceanbrave's Avatar
hummerwalter any luck?
Drumwzrd
Jul 3, 2021 01:42 PM
Chava Vital
Dec 14, 2013 04:52 PM
0sixH3
Dec 28, 2012 10:16 PM
tavion2378
Jul 16, 2008 07:44 PM
jmrknr
Aug 7, 2006 12:57 PM
