Replace Front Impact Sensor (GM# 15177813)
Old Aug 14, 2013 | 07:20 PM
accely's Avatar
Default Replace Front Impact Sensor (GM# 15177813)
FT IMPACT SENSOR - 2004 Hummer H2 (15177813)
Is what I'm told by the body shop is 'probably' what is throwing up the error on my dash "service air bags". They told me the part number and said that 9/10 this will fix it, if you replace this part in the front bumper, but they can't be 100% without an electrical diag which costs more.
I found the part online for around $100 and I have the 2004 H2 Service Manual. Has anyone replaced this on their hummer? I can't imagine it's too hard once you get to it.
Also, is it true my air bags would NOT deploy if I was in a wreck since the sensor may be at fault?
Old Aug 14, 2013 | 10:38 PM
calif phil's Avatar
I would think it's easy to replace. Be sure and disconnect your battery before hand. Yes if the air bag light is on they will not deploy in an accident.
Old Aug 23, 2013 | 01:22 PM
Lomew Bartho's Avatar
Hey Accely for knowing more about its replacing visit that url:
pdfrepairmanual.com/search/how+to+replace+front+impact+sensor
Old Sep 4, 2013 | 08:36 PM
accely's Avatar
Well after some more research I've decided to order 2 of these. I removed the skid plate and could see them. I will update again when I get them replaced, hopefully the light goes out! Seems to be the main culprit according to their videos on the dorman website
DORMAN 590-202 fits GM 03-04 Front Impact Air Bag Sensor
Old Sep 5, 2013 | 05:55 AM
mrdth's Avatar
Interested in how you make out I'm having the same issue. Dealer confirmed bad sensor and recommended replacing both.
Old Sep 5, 2013 | 12:49 PM
lionel90's Avatar
+1 Same issue, so very interested too.
Why both ? Are there two front sensors ?
Don't hesitate to take pictures...
Old Sep 6, 2013 | 08:09 AM
accely's Avatar
yes there are two, I ordered two just because I don't want to only replace one. I'll take pics when they arrive and when I install them.
Old Mar 5, 2015 | 11:55 AM
budzilekjr's Avatar
Hi do i need to take the skid plate off or just the frnt bumpet to get to airbag sensors ? Thank you
Old Mar 6, 2015 | 07:37 AM
accely's Avatar
Just the skid plate
Old Mar 7, 2015 | 08:27 AM
budzilekjr's Avatar
Thank you
