Rear Seat DVD Entertainment System
Old Feb 3, 2020 | 10:27 AM
TeeStu's Avatar
Default Rear Seat DVD Entertainment System
I am looking to add the Headrest Monitors and rear seat DVD. For those who have it, would you go OEM or after-market ? If OEM, where does the DVD deck mount ? Does it interface with the OEM Navigation Head unit ? Is there a different console to mount it in ? What all components do I need ??? This is for 2005 H2...
Old Feb 4, 2020 | 03:13 PM
Chrmer3's Avatar
search ebay- You can usually find everything there
Its stand alone, it does NOT integrate to the stock radio/nav unit, other than if you use the selector for fm channel to broadcast sound.
The entire system sits in the center console.
Old May 29, 2020 | 06:15 PM
bikerbum's Avatar
Actually there are two different OEM headrest systems. Earlier H@ the screen in the headrest was just a monitor and the player was integrated into the stereo. Later on they moved to headrests with each one being a separate DVD player/monitor combo. Finally, I believe in 2009 they went to the same roof mounted version found in Escalades. Mine is an 08 and it came with the DVD/Monitor combos. They were both inoperable when I bought the vehicle thanks to a bungled theft attempt. I have yet to find replacement OEM head units anywhere. The older style monitor only with all associated gear that mounts under the center console can be found on eBay. I intend to just get a set of plain headrests and remove the DVD players since they cannot be fixed.
Old Oct 25, 2021 | 10:49 AM
Diodedave's Avatar
You wouldn't by chance still have your old DVD headrest, that you would let go for a cheap price. I am considering getting something like that for our two little ones for the long trips. I used to repair consumer electronics years ago and they might be repairable.
gracep9
Jul 6, 2013 11:38 PM
bikerbum
Dec 17, 2012 08:32 PM
canoncitykid
Dec 1, 2009 08:17 PM
2HwolleY
Jan 1, 2009 10:03 PM
forsell
Mar 23, 2008 10:56 AM
