Rear Diff fluid leak
Old Jul 25, 2019 | 08:10 PM
Bugly's Avatar
Default Rear Diff fluid leak
Hello all,
2005 Hummer 2 150000 miles. Last week it was 97 degrees here in NE Pa. and I noticed that fluid was leaking from my rear Differential. Looks like it was coming from the yoke, maybe a seal. I would check it after each short trip and it would leak a medium size spot then stop. I spoke to a mechanic friend who said it may be due to the excessive heat. This only happened on the one hottest day. I have driven it all this week with no signs of a leak. Could it be the heat thinning out the fluid too much at that time? I plan on having the seals replaced but want to see if it can wait. Any help is appreciated.
Kevin
Old Jul 25, 2019 | 08:29 PM
Pinion seal failing, In the meantime rear diff fluid change time...
Old Jul 25, 2019 | 08:41 PM
Bugly's Avatar
Thank you for the reply. Thanks also for the proper weight oil. Was my next question
Old Jul 25, 2019 | 09:53 PM
no problem. the pinion seal is not a difficult repair, and a $12. part. Right now just drain and refill the fluid make sure it is full and use a quality fluid. I recommend rp maxgear. Make sure to monitor the fluid level if it still leaks before you replace the seal. GL
Old Jul 26, 2019 | 06:24 PM
Bugly's Avatar
Thank you again very much..
Kevin
Old Jul 26, 2019 | 06:41 PM
Kevin
I forgot to add, make sure to check the condition of the vent tube. GL
mthoodh3
Dec 5, 2016 10:53 AM
vanzachten
Sep 15, 2014 06:24 PM
hummerboy813
Aug 21, 2011 08:01 PM
H3_2009
Dec 14, 2009 06:02 PM
SedonaBoundH3
18
Jan 25, 2007 06:09 PM
