Radiator/trans cooler blew up inside 🤬
Out driving the H2 and the transmission went HOT and it started blowing coolant all over the place. Well, I guess after getting ticked and driving it home at 10mph (yes while it was pukeing all over the place and steaming) I let it sit for the last couple of weeks and seemed that the transmission cooler inside the radiator split and transmission fluid went into the coolant. So transmission didn’t have any fluid in it (it’s ruined) and I need to drain coolant system and get it cleaned. Hopefully nothing else was damaged besides tranny and radiator.
Has anyone went with an aftermarket radiator and just went with a larger or kept the same external tranny cooler?
not wanting to go with another OEM one because the last two times I replaced it (from leaks) it was about impossible to find plus I starting to think, from my personal experience, these radiators are JUNK.
thanks!
thanks!
Most install an aftermarket tranny cooler and bypass the factory trans cooler. Some have gone aftermarket all aluminum radiators. The unfortunate part is, you may have coolant in your tranny which has the potential to destroy the transmission.
I had the same problem but I heard it crack while I was flushing the transmission. I went with a becool radiator and it was not the cheapest route but I still wanted to use the transmission heater/cooler in the radiator. I also upgraded my transmission cooler while I was in there. A few people here are using more affordable aluminum radiators and they are happy with them. I also flushed my system and went with Evans waterless coolant. I’m very happy with the end results and I will never have to worry about it again. Changed stat and hoses, belts too. I found a Mitsumoto after the fact that looks really good.
mdromanelli
Sep 22, 2012 08:16 AM
