Programming Remotes For Different Drivers
Old Jul 7, 2018 | 08:32 PM
Drumwzrd's Avatar
Default Programming Remotes For Different Drivers
I see tons of threads on adding remotes but no one seems to mention how to address them as 1 and 2 for the auto seat positioning. When you program the new remotes, does the vehicle automatically recognize the 1st remote programmed as user 1 and the second remote as user 2 ?
Old Jul 8, 2018 | 08:29 AM
It is in the owners manual. I'd have to look in the manual but I'm pretty sure you first use one of the two remotes, get in start it up, set everything the way you want, seat, mirrors, etc, then press and hold one of the two memory buttons on the drivers door until it beeps. Then repeat the process for the other one and use the second memory button.
Old Jul 8, 2018 | 10:17 AM
Drumwzrd's Avatar
I understand that part, but the remotes have to be already configured as 1 and 2 for that feature to work. The factory remotes have a 1 and 2 engraved on the back of them. Right now I only have a "2" remote. I'd like to just buy 2 new replacement remotes. When you use a remote, the display in the vehicle says "Driver 1" or "Driver 2" based on the engraved number on the rear of the remote from the factory. How do I learn in 2 new remotes and address them as 1 & 2? When you learn the new remotes into the vehicle, is the first one considered "Driver 1" and the second remote you learn into the system "Driver 2"?
96wagon
Feb 24, 2018 10:16 PM
a7m1
20
May 10, 2017 05:04 PM
drtom
Jul 8, 2010 12:03 PM
drtom
Dec 29, 2009 06:59 PM
bham57
Jul 6, 2009 01:20 PM
