Problem with 2004 Hummer H2 Driver Mirror
Old Feb 28, 2021 | 05:22 AM
PanchoH2's Avatar
Default Problem with 2004 Hummer H2 Driver Mirror
Need help with 2004 Hummer H2... The driver side rear view mirror does not fold in or out. The R side works fine. I can adjust both mirrors without a problem. I can manually fold the mirror in and out. I do not hear the motor working at all when i press the button , only the R works. Is this a problem with the door module switch or is the motor that folds the side mirror dead... I don't think there is a fuse that controls only the folding motor.. Can someone tell me what to do ??Thanks
Old Feb 28, 2021 | 08:36 PM
most likely it is the motor especially if it is the first gen mirrors.
Old Mar 1, 2021 | 03:27 AM
oceanbrave's Avatar
PanchoH2 you will find this video helpful.
Old Mar 2, 2021 | 04:21 AM
PanchoH2's Avatar
Appreciate the help. I will see the video and hopefully have time next weekend to play. I'll let you know how it went...
Old Mar 2, 2021 | 05:09 PM
oceanbrave's Avatar
Did both of my mirror arms using this video.
On the RHS I used silicon grease, on the left a special industrial grease specifically for metal to plastic gears.
Just occasionally in cold weather the LHS sticks 1st time, so silicon is the winner.
Take your time, have some small drills (around 0.04") and some small self-tapping screws to match, oh and btw don't loose the little ball bearing!
Good luck!
Old Mar 21, 2021 | 01:27 AM
PanchoH2's Avatar
Good luck!
I watched the video. Great step by step guide to replace the mirror folding motor. I'll let you know if I achieve the task...
Old Mar 21, 2021 | 09:04 AM
oceanbrave's Avatar
Good luck, I hope you get it fixed.
Not sure how much a new mirror-arm costs but it must be $500 plus,
So it make look like a very tedious procedure, but saving hundreds of dollars must be worth and you keep it original
MLANG381
Jul 2, 2014 08:03 AM
BigDog 1701
Jun 13, 2013 01:14 PM
MattJames07
Dec 22, 2012 11:01 PM
gkhogg
Feb 15, 2009 06:20 PM
DOC4H
Feb 8, 2009 08:34 PM
