possible for motor mounts to be bad? feel a clunk when going over bumps
Old Nov 10, 2020 | 09:15 PM
apollo18's Avatar
Default possible for motor mounts to be bad? feel a clunk when going over bumps
2003 hummer h2 with 250,000 km. sorry i am not very mechanically inclined but over the past few months basically my whole front end is new including shocks, tie rods, ball joints, control arms, wheel bearings etc. i recently for the past few weeks started noticing kinda like a clunking noise or like some type of movement in the front end of the truck when i am going over a bumpy road. it seems to happen the most when the bump is causing the truck to wiggle side to side. for example when i am turning into a parking lot that is on an incline i feel a clunk and a type of shake in the front end of the truck as if something heavy is looose. idk its really hard to explain and i am sorry that i suck at describing. for example when i go over a speed bump i dont feel that type of movement, i feel it more as if i go over a bump where one tire hits the bump and the other tire stays flat on the road.
does this sound like a motor mount broken to you? how can i test if it is?
thx!
Old Nov 10, 2020 | 10:09 PM
sounds more like body roll. check the condition of your body mounts. might also want to check your front diff bushings.
Old Nov 11, 2020 | 07:21 AM
tharber's Avatar
Did you replace bump stops?
Tim
Old Nov 12, 2020 | 12:13 PM
Chrmer3's Avatar
Chinese wheel bearings??
jman1335
Apr 30, 2018 10:14 AM
never2big
Feb 17, 2014 09:33 AM
Deputyj
Oct 4, 2012 02:13 AM
954rrpaulo
Nov 12, 2011 02:54 PM
engbulldog
18
Jun 15, 2011 08:58 PM
