p0300 Hard to Start, Rough Idle, Burning Rich - Solved
Old Nov 24, 2018 | 07:38 PM
Polishshooter's Avatar
Default P0300
Just bought use h3 103k miles driving good then few days multiple misfire in clinder 5 . Now missfire in multiple cylinders change spark plugs but the worst now I driving 35mph with 4K rpm like I be in low gear if I do 50mph my rpm are up to 4/5k and not going down :/ any solution?
Old Nov 27, 2018 | 10:08 PM
yrkdmaxh2's Avatar
Originally Posted by mcioci
I have an 08. The only thing I find for an 08 is a fuel pressure sensor. I’m assuming this is same thing.
Negative, 08-09 is a different system and is actually controlled by the fuel pump control module.
Now if the FPCM take a crap you will have similar issues, and codes as well.
Old Apr 16, 2025 | 11:39 PM
Dynamic19's Avatar
Originally Posted by clsimmon
I just fixed a p0300 and this time it was found to be a fuel pressure regulator. The regulator was spitting fuel directly back in to the intake manifold through the vacuum tube making the vehicle hard to start, rough idle (flooding), and burning rich. If you have these symptoms, it's super easy to verify and fix. You can easily check this by following a diagnosis on a similar vortec engine here: https://www.youtube.com/watch?v=S5Jrwa64LDU
Just pulled the little hose to the fuel pressure regulator and a lot of gas was pouring out. 2003 Hummer H2. Rough idle, P0300 code Multiple Random Misfire. I changed spark plugs, wire prior to the misfire and I thought it was a bad coil. Switched those out too. Ordered the part should know soon if that is the issue! Fingers crossed 🤞🏽
Old Apr 17, 2025 | 09:26 AM
if it was pouring fuel into the vaccume line then it probably is the issue. you probably need to replace your oil as well because of fuel contamination.
Old Apr 17, 2025 | 09:29 AM
Welcome to HF.
Let me point out that you just tacked on a comment to an Old As DIRT Thread from 2018.... that is near SEVEN YEARS AGO! Let's avoid that from here on out, not what we do here. READ: Old Threads/'Necro-Bumping'
mcioci
Jun 14, 2019 07:05 PM
user 956363738
24
Jan 4, 2017 07:11 PM
Justinh
Jan 9, 2016 11:18 AM
Billarmao
Dec 21, 2015 02:18 PM
pakerosny
Jul 2, 2013 12:47 AM
