Need some guidance 2003 H2
Old Sep 17, 2021 | 10:25 AM
RenegadeRomeo's Avatar
Default Need some guidance 2003 H2
Hello gentlemen! Hope everyone is doing well!
I just picked me up a 2003 H2 with some goofy issues going on...... Before we get to deep into this - let state - I'm pretty mechanically inclined - iv done engine rebuilds - transmission swaps ( All that good stuff ) I'm here seeking advice from those who have been there done that - I'm aware of most common issues plaguing GM vehicles and such......
I know lil about the hummer - other then it's made by ( AM General ) and shares parts with most GM vehicles.....
dash reports 327k miles.
No smokeNo over heating.
Slight exhaust manifold leak at start up.
So I picked this vehicle up on the 13th of this week......
It was down south of Dallas........
​​​I drove it the whole way home - with zero issue - however there are things I feel need to be addressed......
( Again this thing survived Dallas rush hour traffic - then drove all the way to okc ) - that says alot......
I have paper work that shows the motor and transmission both are new within the last 5 years.
Most concerning to me - when you first start the vehicle (after setting all night) - the oil pressure gauge will read (10psi) - and sometimes but not always if you let it idle long the gauge will fall to zer0 and the warning lights will flash on the dash ( if you rev the engine - the gauge goes up to 40 50ish psi but as soon as you let off back to almost 0...........However!!!!!!!! As soon as you drive it down the road ( one good pull down the street ) the oil pressure gauge starts showing almost 40psi at idle - then reving it causes it to go as high as 60psi........ And it will remain like this until it is shut off over night...... You can shut it down for a bit and when you restart it - it'll show 40ish psi at idle ( like a normal engine..... I would like some thoughts on this - the motor doesn't make any ticking or knock ( no smoking ) no rattles..... I know I need to get a mechanical gauge on it but I haven't had time..... I feel the gauge is faulty......
My next issues - someone has been playing with the headlight ( I was told they are aftermarket ) - they seem to be just stuck on - no high beam or low beam - just on ( look to me to be stuck on bright ) flipping between high and low doesn't change anything...... When you turn to the right ( they completely turn off ) turning left has no effect.....
​​​​​​ALso the windshield wipers are stuck on - ( fuses is pulled ) - I'm wondering if all this is related to a bad (turn signal switch)​​​​
the transmission also seems to soft **** and act goofy from time to time - typical 4l60e dying transmission ( I have a friend that owns a transmission shop ) so no big deal. We got a beefed up 4l80e with a nice Lil stall - I plain do a cam swap at some point anyway so this issue fix's it's self......
Now I paid lil for this truck - I knew it was gonna need some work - completely aware before I even showed up to look at it.....
Drive wise it handles great - smooth and clean going down the road.....
Id like y'all's advice/recommendations......
Old Sep 17, 2021 | 11:02 AM
Somebody had moderated this thread (had it hidden) and I cannot figure out why................ so I approved it.
Check your oil. If it were me, not knowing what somebody put in there with your fluctuating oil psi, I would change it and put my favorite brand in with quality filter.
Good luck.
Old Sep 17, 2021 | 11:08 AM
Good luck.
Idk when I posted it ( the website said something about not being visible until approved by an admin ) 😐 technically 🔨🔨🔨🔨
Yes sir.... I was thinking of doing that as well.. the oil in it looks super clean as well - even after our long trip.... I run royal purple or castor oil GTX - was thinking of doing a 10/30 or castor oil 10/40..... Just because the extra miles.......
Any downfall to upping the oil weight ?
Old Sep 17, 2021 | 11:11 AM
Good luck.
Everytime I try to post or reply it says it won't be visible until approved!? But don't have a issue posting under the newbie section?
I tried to msg you but won't let me - ? Technically 🔨🔨🔨🔨🔨🔨
Old Sep 17, 2021 | 11:12 AM
Good luck.
Old Sep 17, 2021 | 11:48 AM
Your posts are what I was concerned with, you are able to do that.
I have no control over the rest. HF will not let you message anybody until you have a minimum # of posts, like 10 or ????
Old Sep 17, 2021 | 12:19 PM
Oh ok..... Didn't know what was going on. I thought it was all related.... Appreciate you taking the time to fix it!
Old Sep 17, 2021 | 02:21 PM
you could have a sticking oil pump pressure relief valve. or a bad oil pickup tube O-ring that is not properly seated or shrank
as for lights and wipers i would disconnect the switches at the steering column and see if the problem persist if it does then you know it might be wiring or BCM.
Old Sep 18, 2021 | 07:59 AM
calif phil's Avatar
Stepper motor in oil gauge cluster, o ring on pick up tube, wiper motor circuit board bad, aftermarket headlights, if they are LED or the old HID inserts, then I would replace with stock and bulbs and see how it works, could be the switch like you suggested. Congrats on the new rig. Sounds like a cheap, fun toy.
Old Sep 20, 2021 | 06:13 PM
Thank you sir!
